rear left wheel sticking out? right wheel is flush!
Old May 7, 2008 | 12:22 PM
89hatcher's Avatar
Default rear left wheel sticking out? right wheel is flush!
ok so i put on my wheels and i notice that my left wheel is sticking about 1/2"-3/4" out of the fender well. i look at the right side and it flush with the fender. there are no spacer on the car and the car has never been into an accdent. what could the problem be? could it be the trailing arm bushings causing this? or the lower control arms?
Old May 7, 2008 | 01:34 PM
hondadude_rudo's Avatar
Default Re: rear left wheel sticking out? right wheel is flush! (89hatcher)
in an extreem case, it could be what you mentioned, or most likey, if the wheels are new, the place you bought them from could have sent you one that has the wrong offset. try switching them around and see if it changes.
Old May 7, 2008 | 01:37 PM
89hatcher's Avatar
yeah they are the same offset...all around...everything seems to be flush except that side.
Old May 7, 2008 | 02:56 PM
EG1CR-X's Avatar
U think maybe the stock camber is off? Just a thought
Old May 8, 2008 | 12:21 AM
89hatcher's Avatar
Default Re: (EG1CR-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1CR-X &raquo;</TD></TR><TR><TD CLASS="quote">U think maybe the stock camber is off? Just a thought</TD></TR></TABLE>
how do you adjust it? will try to take it apart this weekend.
Old May 8, 2008 | 01:38 AM
bobjohnson's Avatar
Default Re: (89hatcher)
I think for the rear the camber is set with shims.
Did you try switching that wheel to another hub? It could be the wrong offset, you never know...
Old May 8, 2008 | 10:52 AM
89hatcher's Avatar
Default Re: (bobjohnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson &raquo;</TD></TR><TR><TD CLASS="quote">I think for the rear the camber is set with shims.
Did you try switching that wheel to another hub? It could be the wrong offset, you never know...</TD></TR></TABLE>
no shims stock camber kit...tried on my other wheels same thing..
LSteggyguy
Suspension & Brakes
22
Nov 3, 2012 02:49 PM
whyS0serious
16
Jun 27, 2010 02:27 PM
alamoto
Suspension & Brakes
Jun 26, 2007 08:03 AM
Jeff_B
Oct 22, 2004 12:04 PM
Kanges
May 25, 2004 09:29 PM
