which factory intake for my swap?
Old May 7, 2008 | 04:54 AM
biggdogg's Avatar
Default which factory intake for my swap?
i like the stock look so im curious which intake arm will reach my factory box in my b16 eg. thanx
Old May 7, 2008 | 05:26 AM
chimmike's Avatar
Default Re: which factory intake for my swap? (biggdogg)
uh, why go to all the trouble to motor swap, then use a factory intake?
Old May 7, 2008 | 05:35 AM
mattyfo0z's Avatar
Default Re: which factory intake for my swap? (chimmike)
Because most CAI's or SRI's look like trash? Some people like the simplicity of a stock airbox with a K&N filter or the like. Both types of intakes (aftermarket & OEM) pretty much yield the same results, anyway.
Old May 7, 2008 | 06:44 AM
chimmike's Avatar
Default Re: which factory intake for my swap? (.mattyz_)
I disagree completely. Stock intake piping is not only restrictive, it's not conducive to flow due to it's cheap, poor construction.
Further, why is it common to dyno upwards of 8whp when removing a stock intake and going to a CAI?
saying they're the same is asinine. If you want a stock look, powercoat/paint the cai a flat or dull gloss black. Simple, clean, and better than the crap stock.
Old May 7, 2008 | 07:59 AM
biggdogg's Avatar
i`ve always liked a clean stock look and the last setup i had in my ef with this same motor yielded 182-135 at the wheels. i was very impressed and there wasn`t but a few all moto cars round here who could touch me. not braggin just content. does anybody know which arm will reach my airbox? i tried a few ls arms and they r about an inch too short.
Old May 7, 2008 | 12:24 PM
biggdogg's Avatar
uh bump. i know theres someone with a stock lookin setup that knows. do i have to source a jdm setup or is there a usdm equivelant?
Old May 7, 2008 | 12:59 PM
Pro_14481's Avatar
screw that box, get an intake man
Old May 7, 2008 | 03:06 PM
biggdogg's Avatar
bump
Old May 7, 2008 | 03:13 PM
BryanM.'s Avatar
Resident Gearhead
Subscribed, want to know as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .mattyz_ &raquo;</TD></TR><TR><TD CLASS="quote">Because most CAI's or SRI's look like trash? Some people like the simplicity of a stock airbox with a K&N filter or the like. Both types of intakes (aftermarket & OEM) pretty much yield the same results, anyway.</TD></TR></TABLE>
Agreed, I personally don't care to eek out every single HP possible - near redline at that. Even a little less at low to mid RPM doesn't bother me. Also stock filters are cheaper and easier to change on a stock breather setup.
But if my motor was built NA I would stick with a CAI.
Modified by mcvtec at 6:28 PM 5/8/2008
Old May 7, 2008 | 08:48 PM
biggdogg's Avatar
Default Re: which factory intake for my swap? (mcvtec)
yea i just use a k&n drop filter. plus its alot quieter on the interstate. bump
Old May 7, 2008 | 08:53 PM
superfast666's Avatar
the stock eg one will fit
Old May 7, 2008 | 09:12 PM
lsdB16aEj1's Avatar
Default Re: which factory intake for my swap? (superfast666)
use a stock 95 civic ex or si one. It will fit fine. And there's nothing wrong with having the stock one in there, every once in a while i'll put my stock intake back in, usually in the winter though cuz it rains a lot here. You'll have to make it fit because the bore on the throttle body is smaller on the d series motor.
oovvutt
91
Nov 26, 2009 09:40 AM
amej8
Feb 16, 2006 10:09 PM
oMek
Dec 5, 2003 01:41 PM
Dr. Gonzo
Dec 2, 2001 04:36 PM
