need some help with some stripped nuts on my headers
Old May 6, 2008 | 08:53 PM
teamrpm2's Avatar
Default need some help with some stripped nuts on my headers
so i was taking my stock headers of my d16y8 and i stripped to nuts completely any way i can do it without grinding it or thats the only way they are completely stripped
Old May 6, 2008 | 08:56 PM
1992cxcivicEG's Avatar
Default Re: need some help with some stripped nuts on my headers (teamrpm2)
is the nut striped or the stud, but a 10mm should have gotten them off without a prolbem. you should try and get a pair of vice grips and clamp the nut and give it a good turn, same for the stud, if you may have striped that as well.
Old May 6, 2008 | 08:58 PM
Hanmin's Avatar
thought they were 12mm. pb blaster and vice grips, might work.
Old May 6, 2008 | 08:59 PM
v!taminb16's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992cxcivicEG &raquo;</TD></TR><TR><TD CLASS="quote">is the nut striped or the stud</TD></TR></TABLE>
Old May 6, 2008 | 09:11 PM
teamrpm2's Avatar
Default Re: (v!taminb16)
is the nut tried pliers but made it worse
Old May 6, 2008 | 09:20 PM
egcivic's Avatar
Default Re: (teamrpm2)
craftsman has a tool that removes stripped bolts, if it is the stud just keep trying to turn it the studs screw into the block, so they are able to be removed. if its really hard you can cut a slot in the stud and try to turn it out with a screwdriver.
you can also try to hammer on a smaller size socket onto the bolt and turn it out that way, gets locking lugs off. worth a shot.
Old May 6, 2008 | 09:21 PM
teamrpm2's Avatar
Default Re: (egcivic)
yea i'ma try that, thanks
akces
Sep 27, 2008 03:12 PM
b16greenmachine
Sep 10, 2007 10:13 PM
idriveadelsol7
Oct 1, 2005 06:47 PM
95GSRTT
Apr 30, 2005 05:57 PM
simplegreenmachine
22
Oct 13, 2003 10:35 PM
