JDM EF9 B16 odb0 pr3 bearing sizes?
Old May 6, 2008 | 08:05 PM
dcshoecomp's Avatar
Default JDM EF9 B16 odb0 pr3 bearing sizes?
Hi i have a question for all you genius' out there.
I understand that the 94 del sol vtec has basically the same parts as the JDM b16a obd0 pr3 counterpart..
So my question is if i were to order Main and rod bearings should i just order it for the 94 del sol vtec dohc?
what i hear is there are 5 or so different bearing sizes, i reall dont want anything to blow up.
Old May 8, 2008 | 05:59 AM
dcshoecomp's Avatar
Default Re: JDM EF9 B16 odb0 pr3 bearing sizes? (dcshoecomp)
seriously nobody yet, looks like i might have to post this on multiple forums.
Old May 8, 2008 | 06:44 AM
2fastGSR's Avatar
King of the One Liners
There will always be multiple bearing sizes to accomodate for different casting/wearing . .
Best way to do it is measure exactly what size you need.
Im pretty sure those are the same bearings yes, you just have to know what size/ clearances you want to run
Old May 8, 2008 | 07:10 AM
b19coupe's Avatar
All B series main bearings are the same, but there are seven different sizes. One size <U>does not </U>fit all. You have to measure your clearances in order to determine which size bearing you need at each journal.
Old May 8, 2008 | 09:06 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: JDM EF9 B16 odb0 pr3 bearing sizes? (b19coupe)
B19 is correct. If don't have access or funds to get them measured properly, you can read the codes from the block and crank. They will tell you exactly what is the factory bearings size.
PM me if you need help.
Old May 8, 2008 | 09:10 AM
4g hatch's Avatar
Default Re: JDM EF9 B16 odb0 pr3 bearing sizes? (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">B19 is correct. If don't have access or funds to get them measured properly, you can read the codes from the block and crank. They will tell you exactly what is the factory bearings size.
PM me if you need help.</TD></TR></TABLE>
good man right here
Old May 8, 2008 | 10:32 AM
dcshoecomp's Avatar
Hot damn,
Thanks so much for all your help. It helped me search the web for rod bearing code. found this excellent site
http://www.xproductionz.com/fo...=1029
didn't know the codes were stamped on there.
how hard could it be to measure for bearing sizes? my dad is a electrical and mechanical engineer so he has some sort of micrometer.
how big of a risk is it to take this task on my own?
Old May 9, 2008 | 07:29 PM
dcshoecomp's Avatar
This is what i came up with.... pretty sure i am right does it look like i pointed all in the right place?
VTEC-ALL-DAY!
Dec 17, 2013 04:43 PM
turboex
Jun 14, 2004 01:27 PM
tgreaves
Jan 22, 2004 05:52 PM
gsrcivict
Apr 10, 2003 08:09 PM
TREVER
Jan 12, 2003 02:57 AM
