95 honda civic ex Locked keys in car NEED HELP
Old May 6, 2008 | 05:25 PM
UnknownDC2's Avatar
Default 95 honda civic ex Locked keys in car NEED HELP
I asked a friend to move my car this evening. and he left the keys in the car and lock it. The car has power windows so i can push on the window. I NEED help ASAP
Old May 6, 2008 | 05:35 PM
Schmidt's Avatar
Default Re: 95 honda civic ex Locked keys in car NEED HELP (UnknownDC2)
Pull the window it has some flex
Old May 6, 2008 | 05:43 PM
Hanmin's Avatar
call a locksmith
Old May 6, 2008 | 05:59 PM
genocide43110's Avatar
Hopefully you left the sunroof cover open. Get something and pry the sunroof up, then find something long and thin to stick through the crack and hit the unlock button. That is how I did it.
Old May 6, 2008 | 09:01 PM
hd99white's Avatar
hey, get another honda keys from different vehicle and play with it. I have tried and it works. Let me know
Old May 6, 2008 | 09:03 PM
Hanmin's Avatar
grab the vin number, get 20 bucks, go to a honda dealer, get a copy of the key made, viola, problem solved.
Old May 6, 2008 | 09:08 PM
v!taminb16's Avatar
Default Re: (Hanmin)
break the wiondow and pay the 50$ insurance deductable
Old May 6, 2008 | 09:13 PM
actek23's Avatar
where's your extra key?
at home?? go get it and you are set...
Old May 6, 2008 | 09:16 PM
egcivic's Avatar
Default Re: 95 honda civic ex Locked keys in car NEED HELP (actek23)
a long time ago, in a galaxy far far away i unfortunately locked the keys in my car without a spare around.
jus get a screwdriver go to your drivers or passenger side front window and the back side peel back the rubber a little so u can wedge the screwdriver inbetween the window and the metal of the door then pry open the window, safety windows have a lot of flex so unless your some ripped dude with 50 inch biceps you should be able to get your arm in there to unlock the door. or just call a locksmith and they can jimmy ur car open in about a minute.
gluck
Old May 6, 2008 | 09:20 PM
fryman's Avatar
Could use a slim jim if you know someone with one.
Old May 6, 2008 | 09:26 PM
Nino_eg6's Avatar
Default Re: 95 honda civic ex Locked keys in car NEED HELP (fryman)
yep EG civic has it rite ...if not if u kno any1 that thieves hit em up and i bet they will have it open in seconds....
Old May 7, 2008 | 04:54 AM
Decaf's Avatar
take a wooden chock ( a wooden triangle) pry that between the window and the window frame. then take a coat hanger unwind it so its a straight line, and depending on how your lock is bend the tip or keep it straight. or try calling the police, if you can prove its yours im sure they can help open it for you
Old May 7, 2008 | 07:17 AM
EL Vap133's Avatar
Default Re: (Decaf)
briancain1
Paint and Body
May 3, 2019 02:38 PM
GoldenLeg13
10
Jan 30, 2013 07:29 PM
killaj12
15
Mar 10, 2005 07:02 PM
stew18564
Aug 28, 2004 06:29 AM
