Suspension & Brakes Theory, alignment, spring rates....
One small 5 lug question
Old May 6, 2008 | 04:30 PM
legomytego's Avatar
Default One small 5 lug question
i have two sets of 5 lug wheels and i am going to pick up the rest of the conversion friday my question is can i use my brake lines, e-brake cable, shocks, springs or lower control arms from my 4 lug setup ? i ask cause i have koni yellow shocks now and i would like to keep them and yes i searched
i am thinking i can use my yellows if use my my 4 lug lca ? but i wasent sure about the brake lines and all tho thanks.
Old May 6, 2008 | 05:22 PM
madm@nkey's Avatar
Default Re: One small 5 lug question (legomytego)
Sorry for the dumb question, but what car are doing the swap on?
Old May 6, 2008 | 05:38 PM
legomytego's Avatar
not a dum at all i should have posted its going on a 2000 integra dc4
Old May 7, 2008 | 04:25 PM
madm@nkey's Avatar
Default Re: (legomytego)
You should be able to reuse the shocks/springs, lower control arms (front & rear), and e-brake cables. I am not 100% sure on the brake lines, but you should be able to.
The only thing you should be swapping out are the rear trailing arms/hubs/brakes and the front knuckles/hubs/brakes; especially on a DC.
I did the same swap on an EM1 and was able to reuse everything except the brake lines.
Good luck with the conversion!
Old May 8, 2008 | 02:59 AM
legomytego's Avatar
thanks thats perfect all i needed to no
Old May 8, 2008 | 09:35 AM
legomytego's Avatar
another question do you run the 32mm axle or the 36 ?
Old May 8, 2008 | 10:44 AM
madm@nkey's Avatar
32 mm axle/hub from a CTR.
If your donor car is a CTR or USDM ITR it will have 32 mm axles/hubs.
Old May 8, 2008 | 01:25 PM
legomytego's Avatar
yea the donor car has a 36mm setup so i guess its prelude/crv axles right ? thanks man you been more then enough help
CRXz6
11
Jul 5, 2012 10:26 AM
Steve-
10
Sep 8, 2004 09:58 PM
Thrashin
11
Aug 15, 2004 08:20 PM
ki3t
10
Sep 5, 2003 09:54 AM
