I sprayed Carb Cleaner through the Coolant Loop on my IACV
I had planned to remove the Coolant Loop part(and rubber gasket) before cleaning my IAC Valve, but I stripped a screw on the gold colored piece(coolant loop) and then when I was cleaning the screen on the other side satan took over my body and caused my to spray Carb Cleaner through the Coolant Loop part. So, there is a Thermostat in there, and a rubber gasket holding the piece to the IAC, what are the chances I ruined something? Carb Cleaner tends to eat through **** and I was wondering if anyone had insight on what damage I may have done.
Thanks!
Thanks!
HELLAnorcal
Dec 5, 2007 04:37 AM
