Noise verification
I need someone to verify that the sound I have is the throwout bearing. I hear it at idle, its like a squeaking' and it goes away if you apply light pressure to the clutch pedal. When looking under the hood its not coming from the belts side of the engine its coming from where the motor and tranny bolt together, ie where the clutch is
Sounds like the throw out. Usually it is more of a whirring noise; not so much a squeak.
If this were occurring when you pushed the clutch in, then it would be your input shaft.
Mine sounds like a whirring noise. Squeaks are usually belts but I actually realized all my belts were fine and I had a squeak going on and on somewhere on the opposite side of the motor.
