3point harness mounting, autox application
i recently aquired a RCI "v-style" 3 point harness with the optional anti sub belt.
as the sholder straps merge into one monting strap is it safe to mount it to the rear bumber support bolt in the trunk. with the rear seats folded down.
as this mounts so far back it gives the strap a better angle as opposed to mounting it to the rear seat belt.
i also tried mounting it to the c pillar as some manufactures suggest but this makes my right sholder tight and leaves my left looser.
RCI didnt provide much of an installation guide. i am looking at a roll bar or at least a harness bar in the near future but this is just for the time being...
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">Auto Power 4-point roll bar with harness bar.
been looking into getting one, but altough a roll bar wont take me out of STS the fact that i have to remove speakers would
</TD></TR></TABLE>been looking into getting one, but altough a roll bar wont take me out of STS the fact that i have to remove speakers would
Why would you have to remove speakers? Back when I had my 98 Teg I put an autopower roll bar in and I kept the rear speakers. It was a very tight squeeze if I remember.
I'll see if I can dig up photos.
I have a v style impact racing harness.
I mounted it to the rear upper seat belt mount.
The angle that the shoulder belts should make are between down 5 degrees and up 30 and it easily falls in this range.
You can notice it a little being off to one side but its really not bad.
I only use it for autocross so please dont start the whole harness cage debate thing.
3 Point Schroth Rallye 3 in my old Type R...
And yea, having it mounted to the C pillar looks unusual but it seemed to work fine for autocross, and its the way Schroth recommends the 3 point be installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">Is it possible to use the anti-sub belt with that harness on a stock seat?
(p.s. I am going to dig up those autopower roll bar pics when i get home)</TD></TR></TABLE>
There is no sub-belt for a Rallye 3. It has Schroth ASM (anti submarining mechanism) so you don't need a sub-belt. Using a sub-belt with stock seats is generally a no-no anyways because you have to run the sub strap over the front of the seat cushion, which is not the right way to do it and it really compromises the effectiveness of the sub-belt. More info on that here... http://www.soloracer.com/harnessslot.html
no..
and
thanks
no..
and
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on »</TD></TR><TR><TD CLASS="quote">ya this is for autox so also
i tried it on the c pillar rear belt but it just felt really off and slightly uncomfortable.
ah i was using a sparco evo seat maybe that helped.
You can feel its a little off but really doesnt seem to bother me
i have buddy club seats
regardless of the fact i always have a weird feeling that as soon as i have a harness on im going to flip the car and break my neck....dont ask me why
looking for a roll bar...
SpoolinEK9
Jun 21, 2007 12:44 PM
FuNkDrSpOt
Nov 22, 2006 04:46 AM
