can i remove the stock radio?
i was told honda keeps power window and power lock controls on the stock radio, can anyone vailidate that? If they do Ill hide the thing behind the dash but if not then bye bye stock radio.
98 Civic EX - STOCK
for now..........
98 Civic EX - STOCK
for now..........
dome light problem is easy to fix.
The othe harness that you wont be using for your new radio, splice the lt. green/red stripe wire to the lt. green/black stripe wire and everything should work.
Scosche Industries makes wiring harnesses to help with a Civic install. My '97 Civic had no alarm or keyless entry, so I only lost the use of my dome light. I bought the HA03 to correct this. I didn't want to cut wires, so I bought this plug and took care of the problem.
http://www.scosche.com/scosche/conne...ector-kits.asp
http://www.scosche.com/scosche/conne...und-cables.asp
[Modified by 99IntegraGS, 4:31 AM 7/19/2002]
My GF just bought a 98 Ex last night. No CD. I was thinking about just getting the OEM CD player or 6-disc changer. Where's the best place to obtain a factory CD player?
[Modified by Sushiboy, 9:35 AM 7/25/2002]
o.k., I have a 97 civic ex and I replaced the factory stereo in it.
Correct, the only problem you would have is the valet on the original honda keys but I see you have an aftermarket alarm.
Well, I have an aftermarket alarm too and my door locks AND dome light work fine. Good luck with the install.
gilheaven
Oct 15, 2012 12:20 PM
gato5254
Mar 8, 2007 11:17 PM
clemsonteg
Apr 14, 2006 06:33 PM
