DIY charge pipes
Old Jul 13, 2002 | 08:17 PM
rjardy's Avatar
Default DIY charge pipes
Well as im sure you may have noticed that there has been allot of threads on here recently about making your own charge pipes. Haveing a machine shop at my disposal i plan on doing the same. I have come acros many diferent sites explaining all the things you will need to make these and make them right. Here is a link that i find very usefull and im sure if you are looking into making your own charge pipes you will find it usefull as well http://www.cse.uconn.edu/~yelevich/turbo/turbo.html this site can help you with charge pipes as well as other DIY stuff. They use JC whitney mandrel bent piping, these come in an assortment of sizes and bends. jcwhitney.com , check out there site for more info. With all the diferent sizes offered, you would be able to conjure up any type of charge pipe system and run allmost any intercooler you can get to fit, or none at all. allso if you have any pics of charge pipes that you made your self, feel free to post up pics for all the couriouse guys to see. Just thought i would put this out there and try to answer some questions for some of our "new to turbo members"....i am new to it as well but i think im getting a hang of it i hope that this at least helps answer some questions. feel free to respond or IM me with any questions.
thanks all
Rob
Old Jul 13, 2002 | 08:49 PM
rjardy's Avatar
Default Re: DIY charge pipes (rjardy)
Allright so this isnt as helpfull as i thought it would be
Rob
Old Jul 13, 2002 | 09:11 PM
TurBoTeG's Avatar
nice..this definitely helped me alot since i was ordering piping through JC anyways...saves me alota time measuring everything out
Old Jul 13, 2002 | 09:15 PM
rjardy's Avatar
Default Re: DIY charge pipes (TurBoTeG)
Good im glad it helped out someone!
Rob
Old Jul 13, 2002 | 09:53 PM
TurBoXBirD16's Avatar
It definitely helped many members !
I did post alot of threads asking about charge pipes ! hehe..
but i knew that website, and I knew jcwhitney.com
But I am a bit different, coz I want to keep my charge pipe which goes into the throttle body
that pipe is from the greddy kit...
I got the driver's side figured out already, i just need a U bend pipe
but as for the Passenger's side, I am still not sure, I think that website asked for a U bend, but I think I need a 90 degree elbow for my pipe...
hopefully it will work
Old Jul 13, 2002 | 11:00 PM
rjardy's Avatar
Default Re: DIY charge pipes (xbird)
It sounds like it will work. Good luck and let us know how it goes!
Rob
Old Oct 17, 2002 | 07:02 PM
DUCK COMMANDER's Avatar
saw a few topics about this so i decided to ...ttt
Old Oct 17, 2002 | 07:12 PM
filetofit
Guest
Posts: n/a
WHat do you plan to do at the ends of the pipes where the couplings are clamped on so they don't blow off?
Old Oct 17, 2002 | 07:28 PM
POLLO's Avatar
Default Re: DIY charge pipes (filetofit)
Im wondering the same......
Old Oct 17, 2002 | 07:34 PM
mntdewred's Avatar
Default Re: DIY charge pipes (POLLO)
plenty of clamps. at least 4 per meeting; 2 on each side of coupling
Old Oct 17, 2002 | 07:36 PM
SoulSurfer's Avatar
Default Re: DIY charge pipes (mntdewred)
Weld.
Old Oct 17, 2002 | 07:39 PM
mntdewred's Avatar
Default Re: DIY charge pipes (LSDelSol)
Weld.
and then never disassemble them
"those pipes are nothing Honda Dealer guy" "am i still under warranty?"
Old Oct 17, 2002 | 08:48 PM
legendboy's Avatar
I used thoes instructions when I did my own charge pipes. They didn't fit at all. I had to eyeball everything myself and come up with my own design. It wasn't hard, just need some u bends and a mig!
Old Oct 17, 2002 | 08:53 PM
SoulSurfer's Avatar
Didn't say it would be best for everyone. I have no warranty.
Old Oct 17, 2002 | 08:58 PM
IntegD's Avatar
New User
You dont have to weld them to the t/b....doesnt the honda guy ask what that snail looking thing is? What about that radiator looking thing? If you are going to void the warranty with a turbo kit, then go to the dealer to have them fix it later, just pull the whole thing off...
Old Oct 17, 2002 | 09:11 PM
filetofit
Guest
Posts: n/a
I thought he meant run a bead of weld around each end of the pipes to make a lip and keep the couplings from coming off.
Old Oct 17, 2002 | 09:15 PM
Full-Race Javier's Avatar
try using bead rolled pipes and t-bolt clamps
Old Oct 17, 2002 | 09:26 PM
Arturbo's Avatar
Better than steak
25 Year Member
I see he stole a pic I took last year at SEMA. Wonderful. I dont mind he used it, I just wish we would have let me know.
art
Old Oct 17, 2002 | 09:40 PM
rjardy's Avatar
Default Re: DIY charge pipes (Arturbo)
Thats not my sight sorry Art....
Wow this is old, like months. I was going to go this way but recently a have been thinking against it. As for your question filetofit, i was planing on welding a bead around each of the pipes at the conection points. I was going to use the least couplers i could and weld everything up so it looked really nice, then give it a coat of semi gloss black, or wrinkled finish. But like i said im not sure if im going to do this now or not. That sight says to use 2.5 inch pipe, but i just want you guys to know that 2.5 IS NOT the best way to go. Art and i have discussed this and 2.25'' is the way to go. Volumetric efficiency coming into play. Turbo will waste trying to fill the extra space in the 2.5 inch pipeng. I have been told that 2.25 is good for making up to 500 whp. so keep that in mind. Allso legendboy, i never said that this was a surefire easy way to do it, just something that can help some folks out, allot of setups very, and yes as in any custom DIY project a little creativity is a must.
Rob
Old Oct 17, 2002 | 09:48 PM
Arturbo's Avatar
Better than steak
25 Year Member
Im not mad because his site has good info.
art
Old Oct 17, 2002 | 11:19 PM
zojirushi's Avatar
so 2.5 is bad? doh i have 2.5 on mine, is it really worth my time to change it to 2.25?
Old Oct 17, 2002 | 11:29 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: DIY charge pipes (zojirushi)
Maybe this will help.
https://honda-tech.com/zerothread?id=52391
Old Oct 18, 2002 | 01:02 AM
Charles B.'s Avatar
whew, good thing i already have pipes #6 and #8 in 2.25
integrainside
Feb 9, 2007 12:08 AM
SRd240sx
Dec 15, 2004 06:07 AM
Smokinsax
Jan 26, 2004 11:00 PM
jthelman
Feb 15, 2003 11:32 PM
BoM
Oct 10, 2002 07:22 PM
