Sohc Turbo,good&kinda bad
Old Jul 13, 2002 | 07:48 PM
biassj's Avatar
Default Sohc Turbo,good&kinda bad
I ran 12.8 @ 106, mods are listed in signature. Car is a 93' Civic SI
60': 1.883
1/8: 8.268 @ 84.49
1/4: 12.856 @ 106
I ran 13.1 with a 2.0 60 ft and knew for sure I can go 12's!!!
BAD: blew the head gasket then Rods,rings,pistons, you name it!!
GOOD: 12's on stock Sohc, full interior(2450++ with me), Dohc Vtec very soon!!!
[Modified by biassj, 10:51 PM 7/13/2002]
Old Jul 13, 2002 | 08:07 PM
falcongsr's Avatar
What is this crap?
Default Re: Sohc Turbo,good&kinda bad (biassj)
headgasket, rods, rings and pistons are shot? thats not bad. thats UGLY.
Old Jul 13, 2002 | 08:22 PM
rjardy's Avatar
Default Re: Sohc Turbo,good&kinda bad (falconGSR)
i second the uglyness of it all!
Rob
Old Jul 13, 2002 | 08:48 PM
biassj's Avatar
Default Re: Sohc Turbo,good&kinda bad (rjardy)
it's not that bad, I can stick my hand and touch the crank.
Old Jul 13, 2002 | 09:59 PM
TurBoXBirD16's Avatar
could u still drive ur car back home??
nice time with a sohc...
i can't say STOCK INTERNAL sohc, coz u broke everything.. h aha
good luck
Old Jul 13, 2002 | 10:08 PM
CovertFI's Avatar
can you please show pics!! so your sohc had a completly stock bottom end?
Old Jul 13, 2002 | 11:01 PM
Smashback's Avatar
Damn if you're only looking for 11's you can get that with an SOHC, even in a heavier car. Maybe not with an 18G though..
Old Jul 13, 2002 | 11:12 PM
biassj's Avatar
Default Re: Sohc Turbo,good&kinda bad (mplex2000)
Xbird, ummm... nooo..
I'm looking at the behalf of my rod right now, and the track inspectors found pieces of the block on track. They also found the piston ring that I lost, maybe that's why it blew!
I'll try to load some pics(any good host) and yes it's stock bottom end.
My theory, is that I ran to much retard on the BTM causing the car to misfire. Once it misfire, the fuel isn't getting burn, of course causing detonation.
[Modified by biassj, 2:24 AM 7/14/2002]
Old Jul 13, 2002 | 11:20 PM
biassj's Avatar
I don't mind running SOHC and see if I can run even faster, but since I already have a LS/VTEC setup /w JG victor X manifold, might as will put it in.
Im sure I can go 11's with 18g on the Dohc. I might run 12-15 psi on the DOHC and fine tune it. Cause when I ran the SOHC I never had the chance to dyno it and make it run right. It's only a tempaory setup, the manifold it's not even made for engine. Meaning I'm not getting 100% exhaust flow. So 12's is not bad
[Modified by biassj, 2:21 AM 7/14/2002]
TurboGoKart
Apr 17, 2006 08:39 PM
Eee Kay Nine
Apr 10, 2006 08:27 PM
CALM_AS_A_BOMB
64
Mar 13, 2006 06:35 AM
12SecHatch
Sep 27, 2002 04:41 PM
gubo22
13
Jul 19, 2001 02:40 PM
