My AC compressor doesnt Engage
Old May 5, 2008 | 05:51 PM
Evil Smile's Avatar
Default My AC compressor doesnt Engage
hey guys,
i bought the car last year with my AC system not working. the first thought was it needs charge. well i never got around doing it, so tommorow im gonna take it to a mechanic to recharge it for me.
my question is, if there isnt enough gas in there, could that be the reason its not working? and how much does the recharge cost?
thanks in advance
Old May 5, 2008 | 05:56 PM
duggy's Avatar
Default Re: My AC compressor doesnt Engage (Evil Smile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Smile &raquo;</TD></TR><TR><TD CLASS="quote">hey guys,
thanks in advance</TD></TR></TABLE>
There is a reason for it not having any freon in the system. There might be a small leak somewhere. The AC system has a pressure switch that will only engage the AC system if it has enough freon in it.
Old May 5, 2008 | 06:01 PM
v8killaz's Avatar
check if ur compressor is catching, first fill it up though
Old May 5, 2008 | 06:36 PM
Evil Smile's Avatar
Default Re: My AC compressor doesnt Engage (v8killaz)
thanks guys, im gonna take it for a recharge tommorow. how much are they usually?
Old May 5, 2008 | 06:39 PM
lv6l's Avatar
well if you lucky and reason your ac compressor is not engaging is low freon pressure then my recommendation is to take it to an ac place and have them pull a vacuum and see if it will hold. what's the used on paying them to pump in freon when there might be a chance for it to leak out later on and you're back to square one.
if they say you don't need to pull a vacuum when pumping freon take it somewhere else. they are not doing it the proper way. any real ac place will at least vacuum out the hose and check to make sure it can hold a charge.
Old May 5, 2008 | 08:14 PM
y7turbo's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">well if you lucky and reason your ac compressor is not engaging is low freon pressure then my recommendation is to take it to an ac place and have them pull a vacuum and see if it will hold. what's the used on paying them to pump in freon when there might be a chance for it to leak out later on and you're back to square one.
if they say you don't need to pull a vacuum when pumping freon take it somewhere else. they are not doing it the proper way. any real ac place will at least vacuum out the hose and check to make sure it can hold a charge.</TD></TR></TABLE>
Any real a/c place will never pull a vacuum on a known leaking system. if you pull a vacuum on a known leaking system you will introduce noncondensables. always leak test with positive pressure. only after the leaks are fixed you change the filter drier and pull a vacuum to remove moisture and any noncondensables.
Old May 6, 2008 | 11:43 AM
v8killaz's Avatar
do that **** urself, it takes like 5 minutes and its easier than changing ur oil
Old May 6, 2008 | 12:25 PM
ballinboosi's Avatar
ya do that urself! go to advance and get a can for a few bucks and save time and money. I wanna say they charged my ex around $90 to fill her's up when I could of done it for maybe $20. But yet again she was my ex...haha
Old May 6, 2008 | 01:06 PM
Evil Smile's Avatar
Default Re: My AC compressor doesnt Engage (ballinboosi)
hey guys, just got the car back and its working great. i took to the place, because the cars system hasnt worked in 4 years and i just wanted them to check it and make sure there are no leaks, which i couldnt do at home. thanks for all the inputs
Old May 9, 2008 | 09:31 AM
so what was wrong with it then?
VilanKapot1o3
May 15, 2009 08:15 PM
Draggin99Si
Dec 29, 2006 05:36 PM
slow99gsr
Jul 16, 2006 03:04 PM
tthomass
Jun 12, 2005 12:55 PM
type Gendy
Feb 26, 2004 12:31 PM
