camber kit opinions
im going to buy on monday. so far it looks like i will be getting the ingalls front and rear kits off of groupbuycenter for 235 shipped. anyone have any better prices/brands they have used and recommend?
why not just get washers to shim out the rear? it works thats what I did.. I guess if your going for totally non ghetto or something.. then you can buy the rear shim plates.. but for me.. I'd rather spend the 7 cents on the washers for the rear and apply my money towards something else.. my cars dropped like 2" on Eibach sportlines and Koni yellows and 16" wheels.. and I got it aligned (lifetime alignment plan).. rotate my tires every 3K (at oil changes) and I have no bad tire wear.. just make sure ur toe is in check.. if camber IS a problem for your car then I would still just get a front kit and do the washer thing in the rear..
I put washers on both my cars and together the washers cost under $2 for both cars for the rears... b4 it was like 3 deg neg camber or sumthin lolz
i think most people would agree ingalls is good stuff. i have the progress camber kit, and the rear is just high quality washers and bolts.
(i guess i was thinking i would get something like the ingalls rear) but it works well (eliminating some negative camber), and i still have a little negative camber in front and rear, but that's fine with me. sorry, i don't have any prices.
hmm since a few people have asked me about it incl you (in IM's)... heres some links for the rest of you guys.. I linked these to ALLMOTORDCS in IM's..
https://honda-tech.com/zerothread?id=180018
https://honda-tech.com/zerothread?id=221772
https://honda-tech.com/zerothread?id=226731
https://honda-tech.com/zerothread?id=224954
https://honda-tech.com/zerothread?id=165111
http://www.jdmfan.com/technical/suspension/rear_camber/
