MSD - Digital 7 Set-up Cheap!
Old May 5, 2008 | 06:11 AM
TheWickedOne's Avatar
Default MSD - Digital 7 Set-up Cheap!
MSD Programmable Ignition Model 7530T w/ Noise Filter and Coil
$550.00 OBO
ICM Timing Control:Adjust the ignition timing in each cylinder Program up to 5° of timing retard into each individual cylinder in 0.1° increments.
Run Curvelot a timing curve in 0.1° per 100 rpm throughout the entire rpm range of your engine
Launch Curverogram a timing curve exclusively for the launch If the starting line conditions are less than adequate, you can set a completely different curve for the launch
Launch Retard:Retard the timing up to 15° for 0-2.5 seconds after you launch the car.
Step Retards:Three steps of retard that can be activated with nitrous solenoids or switches.
Gear Retardsrogram a timing retard up to 5° with every gear change
Start Retard:Ease engine cranking with an adjustable retard during start up.
Traction Control Detection:The TCD monitors the magnetic pick-up input signal and if it senses that the signal has been modified, it will set a trouble code and flash indicating that traction control has been detected.
Power
No other ignition system comes close to matching the output power and the Individual Cylinder Management timing system of the Programmable Ignition. To effectively handle all of the ignition's tasks, a 15 MHz microcontroller, reviews, manages and analyzes every trigger signal up to 15,000,000 instructions per second Capacitive discharge circuits combined with an IGBT Coil driver deliver incredible cylinder pressures. Below 3,300 there is of course MSD's powerful series of multiple sparks. This spark series burns in the cylinder of over 20° of crankshaft rotation resulting in improved combustion for a smooth idle, great throttle response and increased power.
RPM Controls
Monitoring the engine's rpm allows you to set shift light points, activation points and rev limits. The Programmable Digital-7 has MSD proven Soft Touch rev limiting controls built in and lets you program several rpm features.
Three Step Rev Controlrogram three rev limits in 100 rpm increments for burnout, launch and overrev protection.
Shift Lightrogram a different rpm setting for each gear change for up to six gears.
RPM Activated Window Switch:Activate a circuit at an adjustable rpm such as a nitrous solenoid, then set another rpm level to deactivate the same circuit.
Old May 5, 2008 | 11:19 AM
Default Re: MSD - Digital 7 Set-up Cheap! (TheWickedOne)
TTT - PM's replied!
Old May 5, 2008 | 06:11 PM
Up
TheWickedOne
Northeast (Sales)
May 5, 2008 06:12 PM
99lspwr
Mar 4, 2004 10:37 AM
zseeanz
Feb 8, 2004 07:23 AM
_Endless_
Aug 7, 2002 10:49 AM
