CTR intake cam install, ignition timing on b18c1 before tune?
hey guys, like the title states i will be installing a ctr intake cam in my gsr soon and would like to know what should i set my ignition timing at before i get it tuned? its my dd and will probably have to drive it a couple weeks before i get a chance to tune it. other breathing mods are a blox v-stack and filter, skunk2 pro series intake manifold, hytech replica header, and 2.5" skunk2 exhaust and test pipe.
so should the timing be fine at 16* or should i retard it a couple degrees to be safe. TIA
Shouldn't be fooling with your dizzy unless your setting it back to stock specs..
16~18* should be fine advance it alittle if you'd like or keep it at 16, make sure your jumping the ecu while your doing..
well i had it set advanced at about 18-20* and i set it back to stock (which i believe is 16*, right?) yesterday so i was needing to know if thats ok or should i retard it some, thanks btw.
i forgot to mention im running on a virgin p30 ecu at the moment also. will that effect anything? i believe the fuel maps are different and maybe a little more lean which is another reason i am wondering about the timing.
p30 ecu is made for a single stage manifold, which i'm hoping you swapped over to from the original GSR manifold.. other then that, you might run a tad bit leaner considering the p30 is made a for a 1.6 liter and not a 1.8 liter.. but it shouldn't be that much.. Invest in a tuneable ecu setup you'll gain alot more then you would just throwing parts into the mix.
oh yeah, i swapped the old stock manifold for a skunk2 pro series and hondata gasket already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9400RPMS »</TD></TR><TR><TD CLASS="quote">p30 ecu is made for a single stage manifold, which i'm hoping you swapped over to from the original GSR manifold.. other then that, you might run a tad bit leaner considering the p30 is made a for a 1.6 liter and not a 1.8 liter.. but it shouldn't be that much.. Invest in a tuneable ecu setup you'll gain alot more then you would just throwing parts into the mix.</TD></TR></TABLE>
i cant afford $1000 for a dyno tune right now so i was going to have my tuner run a type r base map and street tune it from there to get me by.
what about a vafc?
what about a vafc?
$1000 dollars??? for a tune?? on your current setup???? man, shop around that's way more than it should be. Go with stock tuning until you get it tuned, then see what the motor likes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">$1000 dollars??? for a tune?? on your current setup???? man, shop around that's way more than it should be. Go with stock tuning until you get it tuned, then see what the motor likes.</TD></TR></TABLE>
well its alittle over $500 for the hondata and about $80 a pass......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd »</TD></TR><TR><TD CLASS="quote">can anyone tell me where to get hondata for a decent price?</TD></TR></TABLE>
just search on honda-tech....
