coilovers or springs and shocks?
Old May 4, 2008 | 04:42 PM
B18Sleeper's Avatar
Default coilovers or springs and shocks?
guys i have read so much and tried to figure out what to go with but i have no idea. my car will be a weekend warrior that will see the street on a good day in the summers, other than that it will be parked or at the track. i have looked at skunk2 coilovers, tein coilovers, and a ground control spring with koni yellow shock plus many more. but i am still lost, can someone please help me? i am also running a carbing front strut bar, low tie bar, function 7 rear lower control arms, half cage, asr subframe brace, and skunk2 front/rear camber kit. thanks
Old May 4, 2008 | 04:47 PM
Garage 808 Hatch's Avatar
Default Re: coilovers or springs and shocks? (B18Sleeper)
if its going to mainly be a track car, with very limited street use, id suggest the OMNI Power drag coil-overs. i love mine
Old May 4, 2008 | 04:58 PM
B18Sleeper's Avatar
Default Re: coilovers or springs and shocks? (Garage 808 Hatch)
i mean my car right now is gettin a **** ton of my time, money, and work into it. i really dont want to drive it everyday anyways lol. the only times i will really take it out is to a few local car meets they have around here in the spring and summer. So omni are good, i have heard some about them but how do they handle at the track?
Old May 4, 2008 | 05:33 PM
awesomew, many ppl on here run them. off the shelf omni's were on Eggums pro fwd car
Old May 4, 2008 | 05:36 PM
B18Sleeper's Avatar
Default Re: (Garage 808 Hatch)
are they extremely stiff or soft springs?
Old May 4, 2008 | 05:43 PM
Default Re: (B18Sleeper)
the drag rears are extremely stiff. fronts are fairly stiff as well
Old May 4, 2008 | 05:48 PM
B18Sleeper's Avatar
but i thought over the axle needs to be soft cause it will help grab traction but i guess i am mistaken, not the best with suspensions lol.
Old May 4, 2008 | 07:36 PM
97hb's Avatar
Sorry to thread jack, but for the omni drag coilovers w/ 18k rear what about the fronts. 10k or 12k??? About to pick some of these up and wondering about the two rates.
Old May 4, 2008 | 07:50 PM
Lo-Buck EF's Avatar
Default Re: coilovers or springs and shocks? (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to thread jack, but for the omni drag coilovers w/ 18k rear what about the fronts. 10k or 12k??? About to pick some of these up and wondering about the two rates. </TD></TR></TABLE>
http://www.omnipowerusa.com/product.asp?P_ID=122
10 or 12k can be had.
as for the original poster, you may as well go with a coilover set-up. the drag shocks from omni would be ideal, but with the real high rear spring rate, keep the street sillyness around corners to a minimum or you will find yourself looking at the direction you came from in a hurry.
Old May 4, 2008 | 08:28 PM
B18Sleeper's Avatar
Default Re: coilovers or springs and shocks? (Lo-Buck EF)
stiffer rear that i understand but the front must be softer to grab traction better correct? thanks for the link to by the way really appreciate it.
Old May 5, 2008 | 10:29 PM
CETVTOGEM's Avatar
im about to buy front shocks for my SFWD car, im stuck between the 10k and 12k. sure you want stiff to help plant power down but is 12k a bit too stiff?
Old May 6, 2008 | 05:54 PM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">stiffer rear that i understand but the front must be softer to grab traction better correct? thanks for the link to by the way really appreciate it. </TD></TR></TABLE>
you dont want it soft or it will dive on shifts and shock the tires when it comes back up.
10k=560
12k=672
neither are on the 'extremely stiff' side. if your car is on the heavy side (full trim street car) i'd go with the 12k
LukieLuc
Suspension & Brakes
May 15, 2007 05:31 AM
Mikes2000civicsi
19
Dec 13, 2006 01:18 PM
03ephatch
May 20, 2004 10:13 PM
80884
Jul 13, 2003 04:30 PM
Typerc716
Jul 31, 2001 04:53 AM
