Mini-Me Questions
Hi everyone. I am new to this forum and I have a '90 CRX that I am going to do a mini-me swap to. I have a couple of questions that I couldn't find in any of the Mini-me write-ups. First of all, I am going to us a Y8 head, not a Z6. Since I'm using a Y8 head, do I use a Y8 timing belt? Also, whats the best head gasket I can use? I read on the write-up that the Y8 head gasket is probably the best. Thanks for the help. - Dave
The z6 and the Y8 belts are exactly the same. Buy which ever one is cheaper. Just DON'Tt use the A6 belt. It's best to use a cam gear with the set up as the combo will throw the cam timing off.
Thanks for the help, I appreciate it, maybe you can answer this other question: I heard there is a 'special' ARP head stud kit for the A6 block with the Y8 head. Does this special kit exist or is there something else I can do?
The timing will only be off if a 1.5L bottom is used. It is always best to match the timing belt to the head. As for the head gasket, the Y8 one is cheaper (Majestic Honda).
I have not heard of a special ARP headstud kit for a mini-me.
Not neccessarily for any mini-me but one of which for an A6 with a Y8. I read it on one of the past threads on here. Heres the link: https://honda-tech.com/zerothread?id=2223545 Read the 6th post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">The timing will only be off if a 1.5L bottom is used. It is always best to match the timing belt to the head. As for the head gasket, the Y8 one is cheaper (Majestic Honda).
I have not heard of a special ARP headstud kit for a mini-me. </TD></TR></TABLE>
Sorry but this is not correct. I ran a a6/z6 and the timing is off about 3 degrees, which is a good amount. I've dyno tuned a couple of mini-mes and the cam timing will be off. There are no special head studs. I used ARPs on mine and they are the same for all sohc d-series.
quick input, from front of the car the bolt in the left upper corner by the dizzy is a shorter head bolt, and the y8 timing belt has 1 extra rib on it, i used the z6 and it was really tight, y8 fit great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ocnaj »</TD></TR><TR><TD CLASS="quote">So what stud kit do I buy? I looked at the ARP catalog and there is a Y and a Z kit. Do I buy the Y kit?</TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clockwork675 »</TD></TR><TR><TD CLASS="quote">quick input, from front of the car the bolt in the left upper corner by the dizzy is a shorter head bolt, and the y8 timing belt has 1 extra rib on it, i used the z6 and it was really tight, y8 fit great</TD></TR></TABLE>
I believe the extra rib comment is incorrect, timing belt rib count as follows
A6 (and 88-95 nonvtec)=106 ribs
z6&Y8 (and y7)= 104 ribs
VX= 103
VX= 103
dohc4life
Aug 14, 2010 08:50 AM
The Internet Tough Guy
11
May 3, 2006 05:23 PM
SOHC_MShue
15
Jun 3, 2005 06:18 PM
