Push start button with no keys?? how to shut car off
Old May 4, 2008 | 11:12 AM
RedneckRicer's Avatar
Default Push start button with no keys?? how to shut car off
im wiring my car to have a push start button. but how will i shut the car off since i wont be using a key?
anyone got a diagram for this?
Old May 4, 2008 | 11:35 AM
pgpbubble's Avatar
Default Re: Push start button with no keys?? how to shut car off (RedneckRicer)
put a kill switch on the power or ground side of the ecu.
Old May 4, 2008 | 03:51 PM
1 2 NV's Avatar
my power wires go through a "master" switch then to a fused distribution panel then out to the accessory it serves. i cannot push the button to start the car unless the main switch is turned on.
i have no diagram.
Old May 4, 2008 | 04:39 PM
Garage 808 Hatch's Avatar
Default Re: Push start button with no keys?? how to shut car off (1 2 NV)
^^^^ mine is setup the same way
Old May 4, 2008 | 06:37 PM
Im wiring my car right now headlight to tail light got rid of that junk stock harness with endless back tracks and running a painless harness. So ill just make a master switch to hook up the Fuse Box up to it that way i can shut everything off. Thanks for the info guys
Old May 5, 2008 | 05:15 AM
Enzo-Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">my power wires go through a "master" switch then to a fused distribution panel then out to the accessory it serves. i cannot push the button to start the car unless the main switch is turned on.
i have no diagram.</TD></TR></TABLE>
You should be able to push the starter button either way. So if your troubleshooting or just need to bump the engine over you can still do it without starting the car.
Old May 5, 2008 | 05:20 AM
1 2 NV's Avatar
Default Re: Push start button with no keys?? how to shut car off (Enzo-Racing)
i can still "bump" the motor. everything goes through my master and then distributed to the accessories. my pump is on another switch. turn on master and it gives power to the "hot" side of all my other switches including the starter switch. but until i push that button or flip that switch like in on my fuel pump they wont work.
h2oiamwater
Nov 26, 2016 12:48 AM
Jeff the wrench
Sep 9, 2014 09:36 PM
cisco1227
K Series
May 7, 2013 06:14 AM
t3to4e
May 17, 2010 03:33 PM
Honda Crx
Audio / Security / Video
16
Jun 5, 2007 07:35 AM
