changed pads: soft pedal, lost some fluid
Old Jul 13, 2002 | 02:37 PM
Flux's Avatar
Default changed pads: soft pedal, lost some fluid
After changing brake pads the bedal was VERY soft but firmed up, I did notice some fluid leaking onto the garage floor from the drivers side under the master cylinder. Why is it doing this? Help...
Does it just need to be bled more or is something else wrong? Why did fluid leak?
Old Jul 13, 2002 | 02:41 PM
kenji's Avatar
25 Year Member
Default Re: changed pads: soft pedal, lost some fluid (Flux)
If you didn't open any of the brake lines there is no need to bleed unless you already have air in your lines.
The reason you had brake fluid on your garage floor is due to the fact that when you compressed the pistons in the calipers you moved brake fluid back up into the master cylinder and it overflowed. It is no big deal. It almost always happens when changing pads.
Pump the brakes a few times before taking it for a drive and relax. Everything is going to be all right
-kenji
Old Jul 13, 2002 | 02:51 PM
ginsu1797's Avatar
You probably lost fluid when you put the new pads in. If your reservoir was topped off it overflowed when you pushed the pistons in to install the new (thicker) pads. Clean all the oil up (eats paint) and check again for leaks. Also you must bleed your brakes real good in the correct order. I believe it was right rear, left front, left rear then right front. Double check in a factory service manual. Don't drive it if you have any doubts.
Old Jul 13, 2002 | 02:53 PM
Flux's Avatar
Default Re: changed pads: soft pedal, lost some fluid (kenji)
Kenji, that is exactly what happened I just realized. So there is no need to bleed the brakes after losing some? Do I need to top off the reservoir if it is low? (I don't think it will be)
Thanks for the help.
Old Jul 13, 2002 | 03:01 PM
Tweakmeister's Avatar
make one of these...I just made one...a Home Depot special.
the pedal feel is quite noticably firmer.
https://honda-tech.com/zerothread?id=209027
[Modified by Tweakmeister, 12:01 AM 7/14/2002]
Old Jul 13, 2002 | 03:16 PM
Flux's Avatar
Default Re: changed pads: soft pedal, lost some fluid (Tweakmeister)
I've wanted to get a MC brace - but it will kick me out of my autox class....
Old Jul 13, 2002 | 04:08 PM
it's held on by one bolt...just take it out for AutoX'ing
Old Jul 13, 2002 | 05:07 PM
Flux's Avatar
I just bedded in the Endless CC-X pads and they feel INCREDIBLE. I will write up a full review in the next few days.
My brake pedal is feeling soft with some travel before bite - do I need to bleed the brakes or will this firm up over the next few days?
Old Jul 13, 2002 | 06:17 PM
Flux's Avatar
anybody?
Old Jul 13, 2002 | 06:19 PM
Back in Black's Avatar
Rather OG
Bleeding is never a bad idea.
Old Jul 13, 2002 | 06:25 PM
sackdz's Avatar
Default Re: changed pads: soft pedal, lost some fluid (Jason Franza)
Just to reiterate, the bleeding order is not important whatsoever.
Old Jul 14, 2002 | 09:57 PM
yoshi234's Avatar
I shoot brides
I'm not familiar w/ any Endless pads....but maybe they need to be heated up to work properly?
jtrig
May 30, 2011 08:48 PM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
St3v3
Jan 2, 2008 04:52 PM
92integraVTECgsr
Jun 7, 2006 02:57 PM
deviant1
Jun 26, 2003 08:42 PM
