How many of you guys running B20VTEC Turbo + more then 14 PSI on stock sleeves?
Old Jul 13, 2002 | 02:28 PM
Ri5e's Avatar
Default How many of you guys running B20VTEC Turbo + more then 14 PSI on stock sleeves?
Just curious as to how many of you guys are running a B20VTEC Turbo with forged pistons and rods on the stock sleeves with more then 14 PSI?
Old Jul 16, 2002 | 01:40 AM
Ri5e's Avatar
Default Re: How many of you guys running B20VTEC Turbo + more then 14 PSI on stock sleeves? (BG Boost)
ttt
Old Jul 16, 2002 | 06:39 AM
b18b98's Avatar
I think Incognito runs that much boost on his LS/VTEC with stock sleeves.
Old Jul 18, 2002 | 10:07 PM
Ri5e's Avatar
Default Re: How many of you guys running B20VTEC Turbo + more then 14 PSI on stock sleeves? (b18b98)
ttt
Old Mar 1, 2011 | 07:09 AM
lsvx92eg's Avatar
I would like to know also i have the same thing i wanna try 20psi on c16.
Old Mar 1, 2011 | 08:00 AM
rev-speed's Avatar
stock b20v with stock block........
can do 400whp reliable.......
but i would keep it under 30psi
highest we did is 28psi on a junk ebay .57 trim to make 400whp........
Old Mar 1, 2011 | 09:07 AM
Spawne32's Avatar
boost pressure isnt the issue on the stock sleeves, its rpm, balance, and side loading that cause the sleeves to crack, make sure your engine is balanced well, use a main girdle for stability, and dont rev excessively high (b20's were rated to about 6500 rpm from the factory, i would not exceed 1000 more rpm then what they were rated on a monosleeve) and make sure your tuned where you arent knocking
Old Mar 1, 2011 | 01:05 PM
MR.johnson's Avatar
very well put. a block guard might not be a bad idea if your running stock sleeves.....
Old Mar 1, 2011 | 01:28 PM
intense4thgen's Avatar
im block gaurded b20/vtec on stock sleeves running 14psi on a gt3076r. I daily it and im about to go to 16psi with a PTE6265.
Old Mar 1, 2011 | 01:37 PM
Turbo-LS's Avatar
blockguardas are pointless, the sleeves will crack if not tuned properly and not balanced rotating assembly with or without one. The issue with the b20 block is the thin sleeve between the cylinders
Old Mar 1, 2011 | 01:43 PM
DDTECH's Avatar
Yall are all wrong, the only downside to b20 sleeves are the fact they are **** to low rpm/ high load knock. Tuning destroys sleeves. Do alittle search, plenty of people spin b20 bottem ends with rod bolts to 10k...plenty of people boost a daily driven car with 10-15 psi.. its always in the tuning when it comes to a b20..
Side wall angle problems would come into effect but who runs 92mm strokes on a b20vtec turbo motor thats daily driven, let alone on stock sleeves.
Old Mar 2, 2011 | 09:47 AM
lsvx92eg's Avatar
Well thats good news to me.im just hoping to break 400.i got a b20b with a b16a head
ge block guard
eagle rods
je pistons
and a 60-1 turbonetics turbo.
b16bri
Feb 13, 2008 07:00 PM
b20vtech
Oct 2, 2007 02:14 PM
CarAudioPro
Dec 6, 2005 09:37 PM
B00STED Si
May 26, 2005 08:00 AM
itr1236
Mar 10, 2002 05:18 PM
