obd2 gsr reff questions.....which ecu
Old May 3, 2008 | 02:57 PM
hard_boiled_EG's Avatar
Default obd2 gsr reff questions.....which ecu
ok...i've search and haven't found anything...
i have a 92 civic vx...just dropped an 98 gsr in.
when i first got the motor in, i had converte it to obd1, but it wouldn't start until i changed it back to obd2...now i want to reff the motor, i have everything but my only question is that which ecu should i run??? should i run the obd1 gsr ecu??? or should i run the obd2 ecu??? more than likely the motor will get reffed as an obd2 but if i run the obd2 ecu i don't have the plug for the secondary o2...do i have to have that???? or can i run the obd1 gsr ecu???
so which ecu do i have to use to pass reff....thanks
Old May 3, 2008 | 09:56 PM
Default Re: obd2 gsr reff questions.....which ecu (hard_boiled_EG)
anybody.........
tranceologist
Aug 28, 2005 05:05 PM
4drb18ek
Mar 1, 2003 07:42 AM
43MA
Oct 30, 2002 04:58 AM
