obd2 gsr reff questions.....which ecu
ok...i've search and haven't found anything...
i have a 92 civic vx...just dropped an 98 gsr in.
when i first got the motor in, i had converte it to obd1, but it wouldn't start until i changed it back to obd2...now i want to reff the motor, i have everything but my only question is that which ecu should i run??? should i run the obd1 gsr ecu??? or should i run the obd2 ecu??? more than likely the motor will get reffed as an obd2 but if i run the obd2 ecu i don't have the plug for the secondary o2...do i have to have that???? or can i run the obd1 gsr ecu???
so which ecu do i have to use to pass reff....thanks
