CEL #54-Crank Fluctuation Sensor
So i pulled code #54 witht he paper clip trick and don't know what to do? should i just trick the ecu to think it's there somehow?
Modified by lmike6453 at 5:32 PM 5/3/2008
ok so i tried splicing c1 and c4 together, and c11 and c14 together...
now when i start the car i get only cel 9 which is cyp sensor...
i checked my wiring 3 times with resetting the ecu wtf?!?!?
now no cel 54, but cel 9 which is worse
please help
please help
ok fixed it this morning after researching how they work...just posting this for reference for others...
if you were to do the trick found on rywire or ffsquad and actually have a ckf sensor then it won't work....
what you have to do is splice c4 into c1, on obd2a, and snip the blue wire which is positive for ckf sensor...
i spliced in c11 and c14 grounds into each other and left then as is in case a ground goes bad, theres a backup...
oh man im having the same problem. i even replaced the sensor, and im still getting a low voltage 54 code. Is it hard to do what you did to get the correct voltage? any help would help. i cant get my car to pass inspection with light on.
not hard at all if you're the type of guy that messes with wires....
grab some quick connects/tap splicers from walmart(auto section by batteries) and post back if you get stuck...
alright im deff down for doing this. i got some slices, but im having a hard time coming across a diagram for the ecu, i keep finding section a and b, but no c. Any idea where to pickup a good diagram? im pretty sure i dotn have a leak at the waterpump, but im goin to double check, but i dont see how that would effect low voltage at the crank sensor
ok just do what i did...fake the ecu to make her happy...
follow the instructions in this post and get an ecu pinout...
http://www.ff-squad.com/technet/wiring.obd2a.htm
alright i was about to start doin this then i realized im not sure what blue wire you were talking about. so i have to snip the blue wire underneath the engine? or is there an easier was to snip under the dash?
no, you snip the blue wire that is c1 on the diagram by the ecu...i snipped it about 2-3 inches from the ecu so i could rehook it if i need to...it is located as the top left wire on the blue plastic connecter(c)
This is great!I am pulling the same code as well on my ob2a 97 ls integra.I do have a ckf sensor and I was wondering if I did this trick what would be the difference between just doing this trick and actually getting the ckf sensor fixed the right way?
glenners
Honda Civic (2001 - 2005)
May 20, 2016 05:44 AM
1fstlude
Dec 10, 2011 06:24 AM
