How much power do you think I can run>?
I have purchased a block today,, it has JE pistons and EAGLE H beam rods with arp rod bolts, type R water and oil pump, block guard with stock 81.5 mm bore. i think its 9.5:1 ratio. i'll be running a gsr head OR a b16 head with gsr cams,, havent decided yet cause i have both sitting in my garage..
but the head will be stock with arp head studs.. i have a GT35r i wanna run on it but i just dont know what power range i should stay at.. wanna stay safe but run to the limit (what would that safe limit be on a set up like this???) any info would be greatly appriciated
311hp
May 6, 2008 07:43 PM
