spark plugs you would recommend for my setup?
Old May 2, 2008 | 11:23 AM
SilverPanda's Avatar
Default spark plugs you would recommend for my setup?
i am in the process of putting a drag turbo kit on my 2001 honda prelude. i was just wondering which spark plugs you would recommend for me to install on my car. i know i need some with a colder spark, also what kind of oil should i use? royal purple? thanks in advance.
Old May 6, 2008 | 06:52 PM
Default Re: spark plugs you would recommend for my setup? (SilverPanda)
anybody?
Old May 6, 2008 | 07:00 PM
g2daturbo's Avatar
i would order ngk 1095's make sure you set the gap a little tighter then stock for most applcations i usually run .030 but the more boost the tighter you want it... good luck!
jdmturbo1127
May 21, 2007 12:29 PM
lilintegra25
Jan 16, 2007 07:52 PM
frankenstienEk
Jan 15, 2007 04:10 PM
chrisgottigsr
Feb 19, 2006 04:58 PM
