help don't know what could be the problem
Old May 1, 2008 | 09:47 PM
my_gsr_teg's Avatar
Default help don't know what could be the problem
ok i just had a new distributor put in and the turn on the engine and the motor start shaking more then usual like it was gonna die then smoke start coming out so i turned off the engine now i don't know what it could be help plz
its a 94 civic coupe ex
Old May 1, 2008 | 10:22 PM
roycivic92's Avatar
bent or burnend valves? hea dgasket ,maybe.
Old May 2, 2008 | 01:08 AM
speedooo's Avatar
Default Re: (roycivic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 &raquo;</TD></TR><TR><TD CLASS="quote">bent or burnend valves? hea dgasket ,maybe.</TD></TR></TABLE>
uh no.
you probably mixed up the firing order
Old May 12, 2008 | 07:18 PM
my_gsr_teg's Avatar
ok i had it checked out they said it was my cylinder 1 and 4 that was uhh low or something so does that mean a new engine is needed?
Old May 12, 2008 | 07:20 PM
elektronsi's Avatar
Default Re: (my_gsr_teg)
what did they mean by "low" did they do a compression test and the pressure was reading low??? explain more
Old May 12, 2008 | 07:23 PM
z6hatchboy's Avatar
Well ovbiously 1 and 4 have low compression if a comp. test was done. Main reasons for low compression are headgasket, rings, timing (crank) being off. This doesnt necessarily mean you need a new motor if you can do the work yourself, but if you have a shop do it then you may be better off to get another motor.
Old May 12, 2008 | 07:25 PM
z6hatchboy's Avatar
What color is that smoke too?
Old May 13, 2008 | 03:03 PM
my_gsr_teg's Avatar
yes it was the compressing on cylinder 1 and 4 is low and i had one of the guys at the shop checked it out he said i needed a new bottom block?
Old May 13, 2008 | 05:02 PM
elektronsi's Avatar
whats your timing like? if you had no problems previos to swapping out the dizzy, then chances are your timing is off
Old May 3, 2009 | 10:06 PM
my_gsr_teg's Avatar
Default Re: help don't know what could be the problem
sorry i finally decided to fix my civic the other day and turns out my timing was way off...so i got that fixed up. thanks for all the info
tackhammer629
Jan 18, 2012 04:44 PM
Under Con. CrX
Feb 20, 2008 10:20 PM
misternguyen
Feb 18, 2007 01:24 PM
geezer06
Oct 26, 2003 04:43 AM
lsvtec42
Dec 6, 2001 12:39 PM
