Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
high rev gear wont go in ...plzzz help !!!!
Old May 1, 2008 | 08:39 PM
warabto's Avatar
Default high rev gear wont go in ...plzzz help !!!!
Hi i have a 2007 honda civic si coupe....
this is my situation ..
i burnt the clutch so i go a new competition stage 2 clutch in instaled in my car with that said when i try shift with an rpm of 2.5-4 it shift good but when i go high rpm i wont let me put in to gear i need to force the gear in or hold down the clutch and apply preasure on the gear for it to go in and at this point the rpm goes right down.
i ask my dealship about the problem and they said that i need to let the clutch settel and let it adjust it self ... and sometime when im stop and i try to put in first i need to force it in and force it back out to take it out ... also my reverse grinds sometimes depending if im on a hill or not ...
thanks
Old May 1, 2008 | 09:46 PM
Blackknight103's Avatar
Default Re: high rev gear wont go in ...plzzz help !!!! (warabto)
im sorry to hear this , unfortunately i am of no path to a solution to your problem
Old May 1, 2008 | 10:19 PM
dirtySOHC's's Avatar
Try to bleed the clutch and check tranny fluid
Modified by dirtySOHC's at 9:57 AM 5/2/2008
Old May 2, 2008 | 09:39 AM
Demonis's Avatar
Did you do the clutch job or did someone else? Sounds like something wasn't put back in properly... Try what was mentioned above, if that doesn't check out, then i suggest you get that thing taken apart and put back together right before you screw up MORE than just a clutch...
New clutch+flywheel = ~600-800
New internals for tranny = ~1500-3000
Old May 2, 2008 | 12:25 PM
knaira112387's Avatar
damn im sorry to hear.. that sucks man.. these k-series trranmissions mannnnnnnnnn!
Old May 2, 2008 | 01:01 PM
ChargedSI's Avatar
I am with Demonis on this one. It sounds like something was not put back right or the wrong clutch was installed. It almost sounds like the throw on the pressure plate is too short so the clutch plate does not fully disengage from the flywheel. Did they replace your throw-out bearing and flywheel as well or just the pressure and clutch plates?
Old May 2, 2008 | 02:47 PM
warabto's Avatar
Default Re: high rev gear wont go in ...plzzz help !!!! (ChargedSI)
thanks....
welll like like this .... i go and this is with every gear ..
i red line and thne i need to hold the clutch down and wait 2-5 sec for the gear to go in .. with out forcing it in...
Old May 2, 2008 | 03:51 PM
sounds like a synchro issue. check the fluid like i said earlier.
if you're engaging the clutch after redlining and the RPM's drop normally then the clutch is disengaging from the flywheel so i dont suspect it to be a clutch problem.
Old May 2, 2008 | 07:51 PM
PolishSasquatch's Avatar
Default Re: high rev gear wont go in ...plzzz help !!!! (dirtySOHC's)
yeah that sounds about right. ( i think) would trying to double clutch(no f&f) to go into gear and if it does prove that it's a synchro problem?
Old May 2, 2008 | 08:42 PM
warabto's Avatar
Default Re: high rev gear wont go in ...plzzz help !!!! (PolishSasquatch)
yeah but its just not one gear its all the gears that they dont want to go in ...... i was talkin to one of my buddies and they said usaly its just one synchro that lets go not all 6
Old May 2, 2008 | 09:13 PM
just check the tranny fluid and go from there. yah one or two synchros go out at a time from abuse but if your tranny is not fully lubricated it could cause the problem you're having.
im just giving you troubleshooting options....you can keep talking to your buddies if you like.
Old May 3, 2008 | 04:14 PM
warabto's Avatar
yeah alrite thats a good idea ill do what your saying and ill keep posting it up thanks....
Old May 3, 2008 | 05:31 PM
HONDAPARTSMANMIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s &raquo;</TD></TR><TR><TD CLASS="quote">Try to bleed the clutch and check tranny fluid
Modified by dirtySOHC's at 9:57 AM 5/2/2008</TD></TR></TABLE>
like he said check the trans fluid if low add some honda mtf. i would also check your shift cables on the trans make sure nothing is in the way of them. do you have cold air intake that could be hitting the shift cable/ assembly, and also the batt calbes run in that area i beleive i would check that. its happened to be before
Old May 15, 2008 | 08:37 PM
warabto's Avatar
Default Re: high rev gear wont go in ...plzzz help !!!! (HONDAPARTSMANMIKE)
Hey guys ..
still dont know what the problem is but ... my dealer ship is gonna fix it ... i havent brought it in yet .... but i do and i figure out what was causing the problem ill let you guys know !
Old May 15, 2008 | 11:12 PM
FlatlineSI28's Avatar
i bet they come up with sme sort of b/s just took take loot form ur pocket
Old May 16, 2008 | 05:13 PM
warabto's Avatar
Default Re: (FlatlineSI28)
its coverd under warantie .. \
thank god
Old May 29, 2008 | 02:18 PM
DIYMIKE's Avatar
Default Re: (warabto)
what was the problem?
Old May 29, 2008 | 09:50 PM
Nighthawk R18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warabto &raquo;</TD></TR><TR><TD CLASS="quote">its coverd under warantie .. \
thank god </TD></TR></TABLE>
congrats.
but how the hell?
i burnt the clutch so i go a new competition stage 2 clutch in instaled in my car </TD></TR></TABLE>
PrettyFastRide
13
Jul 13, 2006 06:30 AM
suken19
Mar 21, 2006 10:00 AM
Greg James
Aug 17, 2004 06:05 PM
loudsubz
May 9, 2004 03:12 PM
skrigz
Mar 6, 2004 01:54 PM
