alignment questions???????????
Old May 1, 2008 | 08:22 PM
hard_boiled_EG's Avatar
Default alignment questions???????????
i need to do an alignment on my 92 hatch...i've heard that it helps out your handling if your rear tires are a couple negitive degree...how many degree do you guys recommend..note: this is my dd...thanks
Old May 2, 2008 | 06:42 AM
nmhuntr's Avatar
Default Re: alignment questions??????????? (hard_boiled_EG)
My guess is the car drives best when within spec. I just had mine done last week. Paid $65 for it and handles great.
Old May 2, 2008 | 06:54 AM
JDM Lyfestyle's Avatar
Default Re: alignment questions??????????? (nmhuntr)
Yea in theory negative camber will help a little bit with cornering but camber kits are overrated imo.
Have you recently lowered the car? I would just get an alignment and leave it at that.
Old May 2, 2008 | 02:24 PM
Default Re: alignment questions??????????? (JDM Lyfestyle)
the cars been lower ever since i had the car...but i just recently installed my rear disc brakes...and after i was don't the driver rear had really bad positive camber...i know thats not normal for honda's usually it would be negative...so i installed my old camber kit...i might just keep it at 0 degree...thanks
Old May 2, 2008 | 03:59 PM
dudeomega2000's Avatar
the rear camber on these types of honda are supposed to be negative to factory spec. look at your alignment sheet to c where your rear camber is supposed to be. I belive it is supposed to be between -0.2 to -0.8 degrees if i am not mistaken
nichols_si
Oct 2, 2003 12:03 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
k-man
Aug 8, 2003 06:41 PM
Understeer
Apr 4, 2003 06:25 PM
rioninja
Aug 22, 2001 02:21 PM
