need help converting civic manual to power steering
Old May 1, 2008 | 06:21 PM
b_boysaiyan's Avatar
Default need help converting civic manual to power steering
i want to know how i can take out a power steering rack from a civic and install it into a manual steering civic i have two civic one with power the other without i want to swap them so i can have power in mine can any one help out thanks
Old May 1, 2008 | 06:22 PM
its a 96 civic hatch both of them
Old May 1, 2008 | 07:19 PM
civicjoe's Avatar
Default Re: (b_boysaiyan)
I'm sure it can be done but why? My CX doesn't have power steering from the factory and I've never wished I had it once.
Old May 1, 2008 | 07:44 PM
i perfer just to have even tho it not a big deal i have done alot of work so far 2000 si front , installed a sunroof in my hatch ,power locks power windows cruise control everything factory 2000 si climate control alot of work into this and now since i have a chance might as well throw the power steering in there as well but wanted to know how its done
Old May 2, 2008 | 05:38 AM
can any one help?
Old May 3, 2008 | 11:51 AM
ttt
Old May 5, 2008 | 08:08 AM
nobody here has done this?
Old May 5, 2008 | 08:12 AM
jeffsciv23's Avatar
never done it but it can't be that hard. just look at both cars and switch over everythign from the PS car to the non PS car.
Old May 5, 2008 | 08:22 AM
grandtheftlunchbox's Avatar
Default Re: need help converting civic manual to power steering (b_boysaiyan)
it's pretty straight forward... pull out the rack, line(s), pump, pump bracket, reservoir, swap them out, and youre done. it's also a good idea to have a front end alignment done since youll be messing with the tie rod ends. just beware, with a lot of cars i've noticed that you have to drop the cradle down to unbolt the rack. if you do this, i HIGHLY recommend you have a lift available to you... it will make the job much easier, and less dangerous.
LockyCharms
Oct 7, 2012 08:43 AM
L0WL1FE
Jan 12, 2012 06:38 AM
O-TownEF
Jul 26, 2009 11:27 AM
1337 Si
23
Apr 9, 2004 12:25 PM
danny
Jun 7, 2002 05:28 PM
