reverse light question????
Old May 1, 2008 | 05:16 PM
sir2sol's Avatar
Default reverse light question????
so here's my scenario....i've got a 93 del sol with a b16a swap, about two weeks ago i was told that i didn't have my reverse lights anymore. i did some research and learned that it was probably my back up light switch on my tranny, so i changed it, still nothing. i checked all my wires and have power everywhere except at my light sockets. i've read that it could possibly be a ground somewhere, but if it was a ground, wouldn't that mean that i wouldn't have taillights, brake lights or turn signals...which all of those work. all this seems strange seeing how i just painted my car and took the taillights out (of course), and they stopped working after the painting process was done. wondering if there could be any connection (or rather no connection ) between those two things. oh yeah and both fuse are good as well as the bulbs, check 'em both at least half a dozen times. anyone have any ideas?
Old May 1, 2008 | 05:20 PM
jdmeg6118's Avatar
Default Re: reverse light question???? (sir2sol)
Have you changed your alternater lately?
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">Have you changed your alternater lately?</TD></TR></TABLE>
Explain.. Please!
Did you replace it with a known working reverse light switch?
Old May 1, 2008 | 05:23 PM
sir2sol's Avatar
Default Re: (Jimmy)
i actually bought a brand new one from honda...guess there is a chance that it's bad...how exactly would i check to see if it was a factory defect?
Old May 1, 2008 | 05:28 PM
jdmeg6118's Avatar
Default Re: (Jimmy)
I had an problem with a new alternater giving to much amp's blew out my reverse light's and some other stuff shorted out.Bad alternater.
Old May 1, 2008 | 06:07 PM
sir2sol's Avatar
Default Re: (jdmeg6118)
fairly sure it's not my alt., i've got a volt gauge and it never rises above 12-13 volts. also my bulbs are all good...but back to this ground thing. a few people have told me to check my grounds, but if my grounds were loose or bad, wouldn't that mean my other lights wouldn't work? there's only one plug on the back of the taillights so doesn't that mean there should only be one ground for the plug?
Old May 2, 2008 | 04:52 AM
sir2sol's Avatar
Default Re: (sir2sol)
ttt
wireprobs
Jun 5, 2014 07:18 AM
davebheam
May 19, 2011 08:42 AM
smurf357
Jul 20, 2008 02:33 PM
JDMegCoupe
26
May 12, 2006 05:52 PM
Dru-Si
11
Jun 2, 2002 08:38 PM
