sos! engine won't start
Old Jul 13, 2002 | 09:15 AM
civicsport's Avatar
Default sos! engine won't start
I did the z6 engine swap, the mechanic took the long way though and change all the wiring, i have the z6 ecu, dist, ect. He tells me the engine is cranking but it's not turning over. Anybody know what could be the problem
Old Jul 13, 2002 | 09:18 AM
CimorelliCRX's Avatar
Default Re: sos! engine won't start (civicsport)
he using everything obd1?
Old Jul 13, 2002 | 03:11 PM
EGHatchy's Avatar
Im having the same problem if he is using obd-1. I have a 92 LS in a crx...car wont start either, and im pretty sure it has somthing to do with my injectors not squirting gas....
Old Jul 13, 2002 | 05:04 PM
djhonda's Avatar
Default Re: sos! engine won't start (EGHatchy)
i have a 95 d15 in my 89 civic hatch and it is not getting fuel from the injectors. yet the distributor is firing the plugs. It will start by squirting gas in the intake if you just want to hear it run for a sec or two i really don't understand why the injectors won't fire.
Old Jul 13, 2002 | 08:24 PM
Louie B.'s Avatar
Did you guys all pull the injector resistor box out of your cars? obd1 injectors run at a higher voltage and if the resistor box is still conected, they won't get enough power to fire.
Old Jul 14, 2002 | 02:10 AM
djhonda's Avatar
Default Re: sos! engine won't start (thumpu77)
my intake and injectors are out of a 91 honda civic si.
Old Jul 14, 2002 | 07:35 AM
shotty's Avatar
Default Re: sos! engine won't start (djhonda)
non obd injectors are a peak and hold type injector while obd1 injectors are saturated. If running a obd1 ecu then you must use the obd1 injectors without a resistor box.
Old Jul 14, 2002 | 10:36 AM
civicsport's Avatar
Default Re: sos! engine won't start (shotty)
I'm gonna let my mechanic know, thanks for the help
Old Jul 14, 2002 | 10:55 AM
EGHatchy's Avatar
first I tried the obd-1 injectors without the resistor box, didnt work...then I tried the obd-0 injectors with the resistor box, and still didnt work..
Old Jul 15, 2002 | 08:35 PM
djhonda's Avatar
Are you guys using a 88-91 distributor with your 88-91 ecu if so it will work unless you dist. is messed up. the distributor in the control the ground side of the injectors and that is what makes them fire. if they are hot on one side and the other side has nothing it is the dist. if it is the resistor box the hot side will not be hot. if you are using an 92-95 ecu you must use a 92-95 distributor. i just did a swap from a 94 si dist. to a 89 si dist. and it all worked.
Old Jul 17, 2002 | 06:53 PM
crxaddikt's Avatar
to be honest, hearing all these posts about swap electrical problems like this, kind of scare me away from wanting to do any kind of swap such as b16a, or z6 head mini me, cause it seems like people always end up having trouble,............and i might be better off keeping things stock with my d16a6, .....................unless anybody else can convince me, lol
accordin 2 me
Dec 16, 2011 06:00 AM
LSV_REX
May 28, 2008 06:41 AM
brnyrdcmndo
Aug 9, 2005 09:24 PM
talagangpinoy
May 26, 2004 10:35 AM
GOLDBERG
Mar 13, 2003 11:07 PM
