0BD0 and OBD1 injectors
Old May 1, 2008 | 12:13 PM
atarigamer01's Avatar
Default running rich...wrong injectors?
Does anyone know how to tell OBD0 and OBD1 injectors apart? Do they look any different visually?
Modified by atarigamer01 at 12:06 PM 5/2/2008
Old May 1, 2008 | 12:30 PM
zccr-xsi's Avatar
well yea u cant use obd1 inj clips on a obd0 inj. plus it also matters if there peak and hold or saturated.peak and hold use a inj. box cometimes mounted on the driver side of the egnien bay(behind the shhock tower) saturated inj dont need a box.
Old May 1, 2008 | 12:39 PM
Default Re: (zccr-xsi)
I'm just confused because I'm running rich. I did a d15b vtec swap in my std hatch (D15b1). From what I think I know, obd1 ecu would need obd1 injectors, unless using obd0 injectors w/ resistor box. I'm not sure if my injectors are obd0 or 1. Assuming the 5th gen civic it came from may have had a resistor box, then it would be logical to assume it was using obd0 injectors right? Should I just buy a resistor box and see what happens or look to buying obd1 injectors? If anyone has info I'd appreciate it.
Old May 1, 2008 | 02:08 PM
zccr-xsi's Avatar
what inj came with the motor?why cant u use them?
Old May 1, 2008 | 04:50 PM
hondaman1212's Avatar
you should be able to use the injectors that came with the engine you have to shave down the civic harness plugs just a tad. you should get a custom chipped ecu
Old May 2, 2008 | 10:14 AM
Default Re: (hondaman1212)
So do you think they could be peak and hold? Its dumping in lots of fuel but Im not getting any error codes and I just had a new head gasket and timing belt put on. Could I have an ecu made to run the injectors at 240cc with out a resistor box? Its running great except for the excess fuel I'm getting.
Old May 2, 2008 | 10:44 AM
zccr-xsi's Avatar
u useing a chipped ecu?if your useing stock inj it should be running rich unless someone has messed with the bin
Old May 2, 2008 | 10:53 AM
I got a chipped ecu from rywire so I think the ecu is good unless I'm supposed to use a resistor box with it. Or get an ecu to run stock injectors...?
Old May 2, 2008 | 01:50 PM
zccr-xsi's Avatar
is the ecu tuned for stock inj?what year car do u have?
Old May 5, 2008 | 12:11 PM
My car is an 88 std hatch. I just assumed the guys at rywire would tune it for stock injectors. Maybe its ignorance on my part though. I'll hit em up and ask about that.
Old May 5, 2008 | 03:12 PM
zccr-xsi's Avatar
yea contact them if they tuned the bin they can tell u evrything u need to know!
Old May 5, 2008 | 03:37 PM
1 Fly SI's Avatar
Check the resistance on the injectors. That way you can identify peak and hold or saturated.
Old May 8, 2008 | 02:37 PM
Default Re: (1 Fly SI)
This weekend I'm gonna try to get my hands on a obd1 ecu just to see if it still runs rich, if it doesn't then atleast I know its the ecu. If it still runs rich Im going to check out the injectors. I really hate this crap! I just took my engine apart too, put new piston rings in, cleaned off all that carbon crap off the pistons. Now there probably black again...aaaaaaaaaaaagggh! Im determined to figure this out.
Old May 20, 2008 | 09:23 AM
Default Re: (atarigamer01)
Just to update this, I found a stock p06 ecu and it runs fine now. No more black stuff in my exhaust or on the outer edge of the tail pipe. No more black specks either on the rear of my car. The ecu isn't vtec though, I'll have to get a vtec ecu later, but it was cheap and I'm glad that solved the problem.
br8crumb
Jun 1, 2014 10:00 AM
surkitroller
Dec 29, 2009 12:58 PM
CRX44
Aug 31, 2009 11:13 PM
si 1
Mar 10, 2006 05:23 PM
CimorelliCRX
May 16, 2003 09:01 PM
