D16Y8 OBD2b ECU pinouts for the primary O2 sensor?
Old May 1, 2008 | 10:02 AM
EX-T's Avatar
Default D16Y8 OBD2b ECU pinouts for the primary O2 sensor?
I believe my harness is messed up and I was wondering if anyone had or knew where to get the ECU pinouts for the primary O2 sensor....
-Grant
Old May 2, 2008 | 07:37 AM
EX-T's Avatar
Default Re: D16Y8 OBD2b ECU pinouts for the primary O2 sensor? (EX-T)
I know someone knows!
Old May 2, 2008 | 09:26 AM
CivicSpoon's Avatar
http://technet.ff-squad.com/wiring.obd2b.htm
C1 & C16 are labeled on that. C18 should also be the ground for it. And the last wire is the Yellow/Black wire that is tied in with quite a few different sensors (like the injectors).
Old May 2, 2008 | 11:02 AM
EX-T's Avatar
Default Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote">http://technet.ff-squad.com/wiring.obd2b.htm
C1 & C16 are labeled on that. C18 should also be the ground for it. And the last wire is the Yellow/Black wire that is tied in with quite a few different sensors (like the injectors).</TD></TR></TABLE>
You're my freakin' hero!!!
jDMJeRk
Oct 3, 2019 08:19 PM
Hanmin
Aug 2, 2008 11:33 AM
EX-T
12
May 24, 2008 08:01 PM
wykid cx
Mar 4, 2003 04:56 PM
Tony the Tiger
Oct 23, 2001 10:55 PM
