Bolting the turbo the the manifold question...
My problem right now is the manifold is threaded and also the turbo.. the holes line up good... do i drill out the turbo threads and then bolt it or how does the screw just go thru? what do you guys do? thanks
On my revhard, the manifold is threaded, and the turbo flange is not..
Just make sure you use lock washers (Revhard kit came with them)..
hmm...I never thought about that. both are threaded on my set-up too...I think I'd have to drill ou the threads on the turbo cause I don't think they'll line up with the manny, even though they're the same pitch. crap. do I need to do this?
RubenPrelude
Feb 28, 2008 07:34 AM
