95 civic jerks horribly under acceleration
Old Apr 30, 2008 | 12:30 AM
notsostockcivic's Avatar
Default 95 civic jerks horribly under acceleration
my civic jerks horribly under accel at about 5% throttle the car feels as if your flooring it letting off multiple times. Its not the mounts i have new poly ones and Ive replaced the tps sensor and burped the cooling system. If you have the clutch in or if its in neutral and you hold it at 5 percent throttle it will rev between 1500 rpm and 2000 rpm up and down.
I also read through the how to on the check engine light and i can not locate the 2 prong plug so hopefully someone has had a similar problem.
car is a 95 lx sedan
Motor is d15b7 with a z6 head
Any help is greatly appreciated
Old Apr 30, 2008 | 05:05 AM
ghostcivic7_41's Avatar
Default Re: 95 civic jerks horribly under acceleration (notsostockcivic)
bump
Old Apr 30, 2008 | 07:21 AM
lshondaeg's Avatar
check ur idle air controll dude
Old Apr 30, 2008 | 07:58 AM
h2b_sedan's Avatar
Default Re: (lshondaeg)
try unplagging your tps and drive it. thats probably it. same thing happened to my old car
Old Apr 30, 2008 | 08:05 AM
biggdogg's Avatar
Default Re: (h2b_sedan)
just fixed dat prob yesterday. my map was bad and my tps was out .5 mv. runs like a champ now.
MinimusMaximus
12
Dec 7, 2016 10:33 AM
jtwarrior14
Mar 17, 2015 12:40 PM
what1118
Nov 12, 2009 06:20 PM
Unseen Racer
13
Jul 12, 2009 03:41 PM
Nyconn18
Mar 12, 2004 07:31 AM
