engine knocking
Old Apr 29, 2008 | 06:25 PM
dev's Avatar
dev
Default engine knocking
i don't know if it's the head or the block. when i start the car it makes a knocking like taping noise for like a second and at idle it sounds normal. but when i drive between like 2500 - 3200 rpm it makes the same noise and is quite after that till like 5000 rpm. but i didn't bring pass 5000rpm cause i don't want the motor to blow. i'm thinking if it's the rockers or i spun a bearing. what do you think?
Old Apr 29, 2008 | 07:24 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: engine knocking (dev)
which engine?
Old Apr 29, 2008 | 07:34 PM
z6hatchboy's Avatar
Might try adjusting the valves first
Old Apr 30, 2008 | 04:51 PM
dev's Avatar
dev
found out it was the bearing
Old Apr 30, 2008 | 06:35 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
how did you find out?
Old Apr 30, 2008 | 06:38 PM
DarikDisease's Avatar
Default Re: engine knocking (oneludesol)
probably the same way i did he took off the oil pan and checked
Old Apr 30, 2008 | 06:47 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: engine knocking (DarikDisease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarikDisease &raquo;</TD></TR><TR><TD CLASS="quote">probably the same way i did he took off the oil pan and checked </TD></TR></TABLE>
I bet not, I think he had someone listen to it and they told him... Nevertheless, most bearing problems that I have heard, come distinctly from the bottom of the motor, are too deep of a noise to be described as a tap, and usually do not go away with rpm (unless there is an oil issue)
Kahl23
Honda Civic (2006 - 2015)
May 16, 2012 08:57 AM
h22apwrdcivic
Jun 8, 2007 02:04 PM
klipstang
Dec 27, 2005 11:40 AM
MrEG6er21
14
Mar 24, 2004 10:33 PM
al3e
Dec 2, 2003 08:01 AM
