valve cover gaskets or lube
Old Apr 29, 2008 | 12:31 PM
IAluder95's Avatar
Default valve cover gaskets or lube
i was curious if you use a lube type sealant on your valve cover or buy the actual gaskets from honda?
parts 3 and 4.
or is using either really necessary?
Old Apr 29, 2008 | 12:38 PM
Acidcrakker's Avatar
Default Re: valve cover gaskets or lube (IAluder95)
Lol, with out those gaskets you will have oil everywhere. You get them cheaper from other places and can also reuse the old ones.
Old Apr 29, 2008 | 12:47 PM
IAluder95's Avatar
i figured that, just wanted to see if gaskets or lube is a better choice.
Old Apr 29, 2008 | 06:37 PM
lude98SH's Avatar
Default Re: (IAluder95)
when you say lube do you mean like a hondabond or permatex type sealant ?
Old Apr 29, 2008 | 06:43 PM
viper_boy403's Avatar
new gasket + some sort of high temp silicone sealant such as hondabond. I really wouldnt try to just use the hondabond lol
Old Apr 29, 2008 | 06:46 PM
lude98SH's Avatar
Default Re: (viper_boy403)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viper_boy403 &raquo;</TD></TR><TR><TD CLASS="quote">new gasket + some sort of high temp silicone sealant such as hondabond. I really wouldnt try to just use the hondabond lol</TD></TR></TABLE>
well if you go by the helms your actually supposed to use both. like you said
Old Apr 29, 2008 | 07:09 PM
jlude90's Avatar
you'll end up with a huge mess if you just use honda bond or something similar
both seals #3 and #4 are Honda on mine, and i don't have any issues whatsoever
Old Apr 29, 2008 | 08:59 PM
gstrudler's Avatar
Default Re: (jlude90)
As long as the gasket is in decent shape, you can reuse it and apply Hondabond at the corners. If not, I think they run like $14 at a dealership.
Old Apr 30, 2008 | 05:50 AM
IAluder95's Avatar
i spent 10 on majestic. so theyll be here saturday.
thanks guys
Old Apr 30, 2008 | 06:55 AM
E-Money's Avatar
its cheaper online, but the price for S&H online your better off going down to your local honda dealer. Of course i mean when your buying one item.
squire
Mar 10, 2008 03:40 AM
20ls01
Aug 28, 2007 03:49 PM
Vitesse
Jul 24, 2006 02:35 PM
92ehatch
Jan 3, 2006 08:52 AM
E-spec Tuner
Apr 17, 2003 09:16 AM
