Non-OEM bolts?
Old Apr 29, 2008 | 09:21 AM
slacks's Avatar
Default Non-OEM bolts?
I have to buy a ton of bolts soon to finish my swap (bolts for the mounts, half shaft, tranny to block... ect..) and the pricing through acuraoemparts.com was $150+!!!
What are your thoughts on using non oem bolts for applications like this?
Old Apr 29, 2008 | 10:29 AM
D50boy's Avatar
Default Re: Non-OEM bolts? (slacks)
if you get some that are aftermarket, buy "grade 8"
Old Apr 29, 2008 | 10:31 AM
Frickr's Avatar
Default Re: Non-OEM bolts? (D50boy)
a bolts a bolt isnt it? the only difference is the strength of it. any grade 8 will handle anything you can throw at it pretty much, a grade 5 would be more then sufficient.
Old Apr 29, 2008 | 10:36 AM
BryanM.'s Avatar
Resident Gearhead
When ever I need a bunch of bolts I go to the salvage yard, I get them real cheap.
Old Apr 29, 2008 | 10:38 AM
ek4_b16a's Avatar
Default Re: (mcvtec)
^^yes, salavage yard will have all the needed bolts cheap too! and they'll work...eheheheh
Old Apr 29, 2008 | 01:14 PM
slacks's Avatar
Default Re: (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">When ever I need a bunch of bolts I go to the salvage yard, I get them real cheap.</TD></TR></TABLE>
that would work but finding bolts like that is next to impossible around here
thanks guys! time to start getting measurements
Old Apr 29, 2008 | 01:27 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">
thanks guys! time to start getting measurements</TD></TR></TABLE>
That sucks man, Honda uses some strang threade pitches and many different length large bolts. I always hold onto the large bolts when I can.
Maybe this thread will help:
https://honda-tech.com/zerothread/1885652
-Mc-
Old Apr 29, 2008 | 01:29 PM
nickybots76's Avatar
As long as you use grade 8 you should be fine. Alot of the bolts do have different length shoulders and some do have ridges in the shoulder but as long as your not making ridiculous h.p. you should be fine. But I will stress to use grade 8
Old Apr 29, 2008 | 01:30 PM
slacks's Avatar
-Mc-</TD></TR></TABLE>
nice info there
i guess i'll have to go with grade 8 bolts since this will eventually be my turbo setup lol
Old Apr 29, 2008 | 03:03 PM
NOFX's Avatar
H-T White Ops
Most people never seemed to see what this thread says.
https://honda-tech.com/zerothread?id=2048988
Basically, every part number Honda has for a bolt has the dimensions of the bolt in the part number. You just have to know how to read it. So if you look up a part number on any of the many sites listed in the OEM Parts Sellers thread, you can figure out what bolts you need.
Old Apr 29, 2008 | 03:06 PM
slacks's Avatar
Default Re: (NOFX)
damn.. stuff like that should be stickied
jughead
26
Jun 6, 2010 02:23 AM
pliskin679
Sep 14, 2007 06:57 PM
civic89si666
11
Dec 20, 2006 11:11 AM
