Non-OEM bolts?
Non-OEM bolts?
I have to buy a ton of bolts soon to finish my swap (bolts for the mounts, half shaft, tranny to block... ect..) and the pricing through acuraoemparts.com was $150+!!!
What are your thoughts on using non oem bolts for applications like this?
Re: Non-OEM bolts? (D50boy)
a bolts a bolt isnt it? the only difference is the strength of it. any grade 8 will handle anything you can throw at it pretty much, a grade 5 would be more then sufficient.
Re: (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">When ever I need a bunch of bolts I go to the salvage yard, I get them real cheap.</TD></TR></TABLE>
that would work but finding bolts like that is next to impossible around here
thanks guys! time to start getting measurements
Resident Gearhead
Re: (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">
thanks guys! time to start getting measurements</TD></TR></TABLE>
That sucks man, Honda uses some strang threade pitches and many different length large bolts. I always hold onto the large bolts when I can.
Maybe this thread will help:
https://honda-tech.com/zerothread/1885652
-Mc-
-Mc-
Re: (slacks)
As long as you use grade 8 you should be fine. Alot of the bolts do have different length shoulders and some do have ridges in the shoulder but as long as your not making ridiculous h.p. you should be fine. But I will stress to use grade 8
Re: (mcvtec)
-Mc-</TD></TR></TABLE>
nice info there
i guess i'll have to go with grade 8 bolts since this will eventually be my turbo setup lol
nice info there
H-T White Ops
Most people never seemed to see what this thread says.
https://honda-tech.com/zerothread?id=2048988
Basically, every part number Honda has for a bolt has the dimensions of the bolt in the part number. You just have to know how to read it. So if you look up a part number on any of the many sites listed in the OEM Parts Sellers thread, you can figure out what bolts you need.
civic89si666
11
12-20-2006 11:11 AM
