2001 civic egine in a 1994 civic
Old Apr 28, 2008 | 04:01 PM
asianmario_one's Avatar
Default 2001 civic egine in a 1994 civic
Have a question if this can be done or if it has been done. I have a 1994 civic ex. I blow my engine. I friend has a 2001 civic ex engine. I what to know if that engine fit into my car.
Old Apr 28, 2008 | 04:06 PM
ltrkstr2k's Avatar
Default Re: 2001 civic egine in a 1994 civic (asianmario_one)
is your 94 a ex?
Old Apr 28, 2008 | 04:50 PM
davefromPA's Avatar
Default Re: 2001 civic egine in a 1994 civic (ltrkstr2k)
it will fit yes. it is however an obd2 engine while your 94 is an obd1 engine. different computers also. otherwise it is a relatively easy drop in
Old Apr 28, 2008 | 04:59 PM
rick1574's Avatar
Default Re: 2001 civic egine in a 1994 civic (davefromPA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA &raquo;</TD></TR><TR><TD CLASS="quote">it will fit yes. it is however an obd2 engine while your 94 is an obd1 engine. different computers also. otherwise it is a relatively easy drop in</TD></TR></TABLE>
you're saying the d17a2 is a direct drop for an ej1? are you sure? because if that were true, that would mean you would be able to swap b-series motors into em2's, and i know for a fact you can't do that. i believe the mounts for the motor are different.
Old Apr 28, 2008 | 05:45 PM
ltrkstr2k's Avatar
Default Re: 2001 civic egine in a 1994 civic (rick1574)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rick1574 &raquo;</TD></TR><TR><TD CLASS="quote">
you're saying the d17a2 is a direct drop for an ej1? are you sure? because if that were true, that would mean you would be able to swap b-series motors into em2's, and i know for a fact you can't do that. </TD></TR></TABLE>
so true
Old Apr 28, 2008 | 08:24 PM
I think that is true. On the D17A2 there is a mount on the front of the engine and there is no mount on my civic for it.
Old Apr 30, 2008 | 08:32 AM
davefromPA's Avatar
im not saying its a direct drop in. im saying it will fit. you will need to fabricate stuff to make it work but thats the fun part. cheers
Old Apr 30, 2008 | 08:35 AM
blk92_d16's Avatar
No, sorry...just not a feasible swap right now. Just find any D-series motor, '92-00!
Old May 1, 2008 | 08:53 AM
-JAWSHUA-'s Avatar
kinda answered your own question.
Old May 1, 2008 | 08:59 AM
skateboard_ej8's Avatar
im hench irl
Default Re: 2001 civic egine in a 1994 civic (-JAWSHUA-)
Its not worth it and you would probably just be better off just swapping in a b series or just finding a replacement obd1 sohc vtec engine.
Old May 1, 2008 | 09:30 AM
ballinboosi's Avatar
Default Re: 2001 civic egine in a 1994 civic (esco562)
the mounts won't match. I actually have a 01 lx and a 94 hatch and I have a spare motor for my 01lx an thought the same thing. Not worth the trouble or wiring and fabricating it. Just get a ls motor and drop in it, that would be the best in my opinion
Old May 1, 2008 | 11:53 AM
95 honda8's Avatar
Default Re: 2001 civic egine in a 1994 civic (ballinboosi)
Its not a direct drop in but you can put a b16 in an 2001-2005 civic, I think it was super street that did an article on it a while back, but still a d17 in a 94 or a b16 in a 2001 is not an easy swap lots of fab work but can be done infact there are more people rock'n b16 in the 7th gen then you would think from what I understand the swap is eaier than a k swap so I am sure a d17 in a 94 can be done with fab work was well
Old May 1, 2008 | 11:58 AM
95 honda8's Avatar
Default Re: 2001 civic egine in a 1994 civic (95 honda8)
I found one that import tuner did an artical on
http://images.google.com/imgre...a%3DN
Old May 1, 2008 | 12:24 PM
03EM2guy's Avatar
switch the speedo-sensor, alternator, distributor, and throttle body. obd-2 b didn't come w/ a tps so you might throw a CEL light. and like some ones else 99' motors and less will swap right in mounts and all. Also you can keep your ecu..unless you want to convert to OBD-2 which is really a waste of TIME IMO.. this is (JDM91CRXSI) not 03em2guy
doa2003
Nov 26, 2018 09:05 AM
1991hb
Mar 14, 2007 08:30 AM
elduro numba1
Dec 7, 2004 02:18 PM
SWATDancer
Dec 1, 2004 03:54 AM
kezay
Jun 25, 2004 10:45 AM
