friend not sure how much to sale car?
car was in a fender bender, the bumper support and radiator support messed up, the frame of car is ok nothing happen to it, the car runs straight IT DOES NOT RUN SIDE TO SIDE OR PULL TO A SIDE. the car is green and in good shape the motor was build ground up..
MOTOR:
block: b18c1
head: b16b shaved head
to go turbo all u need is a bigger seal
it has about 10000 miles on it
TRAN:
it has a ls or gs-r trany?
COMPUTER:
it is a acura type r computer redline at 8300rpm
short shifter
it has a new cluch its a raceing cluch
and it has K-storps suspension all around
bigger disk break,
16in black rims with low pro and more things just cant remember
but how much would be a good price?
put pics later on
Modified by SmoKez at 5:29 PM 5/14/2008
MOTOR:
block: b18c1
TRAN:
COMPUTER:
short shifter
bigger disk break,
put pics later on
http://www.kbb.com will provide a reasonable estimate.
You failed to provide the trim and year for the car. Do not make this into a FS thread.
yeah you really can't determine how much a car is worth without actually seeing it in person. Sounds to me like the shell itself is worth close to nothing, so as a car, I would add up the value of the engine/transmission, suspension, wheels, etc.
Also, does it have a rebuilt title or not? If so, expect to knock off 1 to 2 grand for that. If the car is worth fixing, then I would fix it. You'll get a MUCH easier sale that way, and you'll see more money back into your pocket.
ESmooth
17
Jul 16, 2009 04:45 AM
