main relay buzzing
i just finished doing a swap and now the car wont start. the main relay is buzzing everytime i turn the key to on and the light is really dim but when i take off the ecu or main relay everything is bright agian. i change battery, ecu, main relay, checked thermostat ground and added extra grounds and fuses, and cleaned all ground terminals but nothing seems to work and yea i evened checked all connections what could be the problem?
could it be a harness problem? should i swap the harness? but today i tried using some starter fluid and when i cranked the car it shot out a ball of fire out of the throttle body. and by any chance is the cx engine harness different from an si body harness beside the vtec wires because there were a couple of wire that were different colors. someone help me need to get this **** out of the garage
If the main relay is ''buzzing'' you need to pull the relay and pull the cover off and resoldier the dry joints and that should fix your problem.
Horseofcourse
11
Jan 25, 2009 10:11 PM
