My Car Is Eating Main Relays
Re: My Car Is Eating Main Relays
when you say eating main relays... are you getting a hot-soak no-start like a typical main relay failure? Do you have fuel when you attempt to restart? I've rebuilt many main relays by removing the cover and resoldering cracked spots on circuit board. you can too, but you must be very careful not to solder the pre-existing spots together.
I would think that you are hiding the real problem by changing the main relays. Have you inspected the main relays for a failed solder connection? or tested the ones you have removed?
I will check the grounds. One Relay was the original. 2 where purchased brand new. Im Getting a no Fuel prime/fuel delivery type failure.
damn im going thru EXACTLY the same problem.. i re-checked all the grounds even did a test light on all the fuses...still getting no fuel no spark, constant check engine light the ignition doesnt even beep when u put the key in wit the door open...
/I believe this is a blown ecu fuse/main breaker #25?, added any new electrical lately ? ign kill switch, fuel pump kill, new alarm, new stereo components ?
1 Post
im having the same problem besides my check engine light dont turn on at all no spark no fuel!????? help! doe u think it coulb b the e.c.u???
Jimmy
14
12-21-2004 04:47 PM
