greddy profec b/s
I been trying to figure out if the the greddy profec boost controller vacuum filter is a straight through filter, or is it a one way check valve.
can anyone confirms this?
if it is a one way filter which direction is it installed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">you want it so that the end of the vaccum line that will sense pressure. You want it so that it opens in the valve.</TD></TR></TABLE>
so it is a check valve?
so it needs to be installed so pressure will go in the control box, but not out.
reason I ask is that I have a used box that did not come with one, but I have some one way check valves laying around.
I am limited to 12 psi right now, I wanna run 20 this weekend. the greddy boost controller is messing up, I am gonna have to run a manual one.
the profec is spiking to max boost when I try to boost over 12 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gettin it »</TD></TR><TR><TD CLASS="quote">Dam that sucks bro. is your solenoid good?</TD></TR></TABLE>
brand new
I called greddy and they say the main unit is bad, I ask for them to repair or replace it and they say too bad, they won't because its discontinued, so I need to buy a new unit. really sucks. I always thought greddy sucked now Its confirmed.
brand new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">
brand new
I called greddy and they say the main unit is bad, I ask for them to repair or replace it and they say too bad, they won't because its discontinued, so I need to buy a new unit. really sucks. I always thought greddy sucked now Its confirmed.</TD></TR></TABLE>
hehe i have had their profec, turbo timer, emanage, 2 bovs, and none of them lasted a year, and greddy told me to take a hike every time... IMHO no name ebay stuff > Greddy!
brand new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gettin it »</TD></TR><TR><TD CLASS="quote">Dam, that sucks bro. So what are you going to get next? </TD></TR></TABLE>
for this weekened I am using crucians profec b.
then I will be in the states (miami) for 2 weeks I will have mine tested to see whats messed up in it.
if not I will go hondata boost, I can use the greddy solenoid that I wasted my on.
porkythegrunt
Jul 25, 2012 10:40 AM
