tranny noise?
Old Apr 28, 2008 | 04:53 AM
Vt3c_eg's Avatar
Default tranny noise?
okay i put in a d16z6 motor with a d15 tranny in my 92 hatch back and when the car is on you hear this noise, but when you step on the clutch pedal the noise stop? only happen when clutch is not step on. any idea what it is?
Old Apr 28, 2008 | 05:06 AM
dividedas1's Avatar
Default Re: tranny noise? (Vt3c_eg)
input shaft bearing...
Old Apr 28, 2008 | 05:21 AM
Lmgrcivic's Avatar
Default Re: tranny noise? (dividedas1)
it could also be your clutch. depending on which one you have in there
Old Apr 28, 2008 | 07:58 AM
v8 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 &raquo;</TD></TR><TR><TD CLASS="quote">input shaft bearing... </TD></TR></TABLE>
Old Apr 28, 2008 | 08:32 AM
biggdogg's Avatar
Default Re: tranny noise? (v8 integra)
throw out bearing! just had to do mine. sounded like a rod knocking .
Old Apr 28, 2008 | 11:07 AM
dividedas1's Avatar
Default Re: tranny noise? (biggdogg)
look this is easy...ive bought 3 different trans to get rid of that EXACT noise...
when you press the clutch down the noise goes away = ISB
When you press the clutch down the noise is there = Problem with the clutch (throw out bearing or w/e)
search
Old Apr 28, 2008 | 11:11 AM
dividedas1's Avatar
also look at it like this... when you press the clutch in the input shaft (the part of the trans that spins) isnt getting the same load from the clutch that it would when you are driving it hench why i say its the ISB. No load on the trans equals no noises means its inside the trans. But if it was opposite and when you pressed the clutch you had a bunch of awful noises it would be something moving in the clutch doing that.
Old Apr 28, 2008 | 11:23 AM
CraZyxx978's Avatar
Old Apr 28, 2008 | 11:31 AM
Vt3c_eg's Avatar
Default Re: tranny noise? (CraZyxx978)
thnx all. that suck! ill just have to buy a new tranny!
shermanyang
Dec 1, 2012 11:24 AM
lurkin' eg
Oct 2, 2007 06:36 PM
jimbrown
Jul 17, 2007 12:35 PM
B18B EK
Feb 20, 2004 07:19 PM
garados
Feb 3, 2003 11:08 AM
