need help with vacum line on my turbo ls!!!!!!!
ive got a 97 integra obd2 running a chipped p28, b18b1 stock, with an external wastegate setup, can anyone give me help setting up the vacum lines? im not sure if i have them right, let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">how do you have them set up at the moment? pics?</TD></TR></TABLE>
first off it is never sunny in WA lol
and for vacum lines, since there is only two vacum ports on the IM, and one of them goes to some sort of sensor, which does not output vacum as soon as the car is warmed up, i have the boost gauge and BOV t-d off the line that goes from the IM to the fpr, and then i have nothing going to the top port with the black sensor on it, and there is actually one more on the front that has a line which goes to the pcv valve.
then the line from the turbo is going to the side port on my turbonetics deltagate labeled "boost", not the one on the front labeled "vacum"
please and thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_am_a_black_man »</TD></TR><TR><TD CLASS="quote">
the fpr is an ok place to put the bov hose
im not too familiar with turbonetic wastegates..are you having boost problems right now? maybe the 'boost' nipple is used for a boost controller so if you dont have one might need the vacuum line going to the vacuum port
i just drove it without the bov hooked up, its a 10 pound spring but only pushed 6, might be because of a leak somewhere, but bogged on the upper end so idk now maybe its just my dizzy or something and not a vacum problem
i_am_a_black_man
Apr 28, 2008 07:40 AM
i_am_a_black_man
Apr 27, 2008 09:30 PM
almostboostedgsr
Mar 14, 2007 08:23 PM
