Suspension & Brakes Theory, alignment, spring rates....
Front subframe reinforcement?
Old Apr 27, 2008 | 08:14 PM
MrXclusivE's Avatar
Default Front subframe reinforcement?
I am installing sir front lca's and sway bar (26mm) into a 98 ek hatch, is the front subframe same between the dx and the sir or I'll need some sort of reinforcement to prevent damage?
thanks
Old Apr 27, 2008 | 08:36 PM
bpr0422's Avatar
Default Re: Front subframe reinforcement? (MrXclusivE)
i've never read anything about having to reinforce the front subframe for a swaybar...
the rear, thats a different question...
Old Apr 28, 2008 | 06:54 AM
MrXclusivE's Avatar
Default Re: Front subframe reinforcement? (bpr0422)
I haven't heard either, but I'm adding a 26mm bar to a subframe that didn't have a bar from factory, want to make sure it won't screw anything up.
Old Apr 28, 2008 | 11:28 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrXclusivE &raquo;</TD></TR><TR><TD CLASS="quote">I haven't heard either, but I'm adding a 26mm bar to a subframe that didn't have a bar from factory, want to make sure it won't screw anything up.</TD></TR></TABLE>
I believe that the steering rack and transmission mount will exert more force on the front subframe than the swaybar ever will. I wouldn't worry about it.
ejoner
Dec 2, 2007 06:56 PM
SpoonKid
Oct 26, 2006 11:05 AM
jdm_23_eg6
Suspension & Brakes
Apr 9, 2005 11:56 AM
lowgman
May 11, 2004 11:12 AM
JMD
Apr 13, 2003 07:30 PM
