Competition Clutch twin disk stripping spines out of 1 frictionb disk????
Old Apr 27, 2008 | 11:22 AM
extralargenog's Avatar
Default Competition Clutch twin disk stripping spines out of 1 frictionb disk????
Happen to anyone else??? Now 3 of us have done it locally (mine after 6000 BEATEN miles so Im not mad... LOL)... Just curious...
Started out of NOWHERE.... just came to a stop, went to take off in 1st and it sounded like a terredactyl on crack screaching and ****... My buddy had told me about a month ago that something like this happened to his too... Another still had it happen to his replacement disks he purchased recently...
1st was a K series,
2nd was a B
Mine's an H
The two other guys had less than 100 miles on theirs... The K series one that **** the bed was brand new, hes making about 320WHP. THe B series car were replacement disks (no problems with the originals).. Lasted a month (Rarely beaten) 450WHP...
And mine had 6K on it, ive broke 7 trannys beaten contantly at 630WHP... LIke I said I ubnderstand why mine might have failed... but would never think the splines would break off of the disk.... I have a Tilton flow control valve with the smallest pill in it too..
WTF???
Modified by extralargenog at 9:16 PM 4/30/2008
Old Apr 27, 2008 | 04:05 PM
Tex Blackwell's Avatar
Default Re: Competition Clutch twin disk stripping spines out of 1 frictionb disk???? (extralargenog)
We have never had a problem with the twin disks...you should give them a call.
Old Apr 27, 2008 | 04:23 PM
Garage 808 Hatch's Avatar
Default Re: Competition Clutch twin disk stripping spines out of 1 frictionb disk???? (Tex Blackwell)
i had only heard of this being a problem with the 90-91 integra small shaft trans kits
Old Apr 27, 2008 | 06:17 PM
vtecspeed1320's Avatar
Shooting Star
I just went through this with a tilton twin, and a friend of mine did the same. Both on k series. They are working on fixing the problem for me. Good luck.
Old Apr 27, 2008 | 07:39 PM
Antilag's Avatar
Default Re: (vtecspeed1320)
Only time i see this happening, is when you don't have the tranny dowel pins between the block and tranny. Hope you guys have those in. Otherwise i'm scratching my head why it would do this.
Old Apr 27, 2008 | 08:02 PM
reaction360's Avatar
Default Re: (Antilag)
it happened to me, i didnt have nearly as many miles on mine as you did, hadn't even done the first 3000mile oil change yet. here was my post from a year ago. I ended up having to buy a pair of new discs.
https://honda-tech.com/zerothread?id=1942010
Old Apr 27, 2008 | 08:08 PM
****, thanks Zol...
oh also, dowels are in place.
Old Apr 27, 2008 | 08:29 PM
V-SPEC 1's Avatar
Default Re: (extralargenog)
That happen to my buddy's car as well. Probably have about 6k miles or even less than that and even the disc itself got so worn out bad. Competition Clutch took care of the problem.
Old Apr 27, 2008 | 08:54 PM
fast forward driver's Avatar
Default Re: (V-SPEC 1)
just call them , chris @cc has been always great since we started using/selling there products
Old Apr 27, 2008 | 09:05 PM
Default Re: (fast forward driver)
Thanks you guys. I PMed them.... Ill cal them tomorrow as well.
Old Apr 28, 2008 | 01:06 PM
h22 civic's Avatar
no probs with mine yet *crossesfingers*
bye the way are you using a clutch stop?
Old Apr 28, 2008 | 01:52 PM
Default Re: (h22 civic)
No... Thats not it thoug. Mine doesnt over extend itself to where that is any issue though....
Old Apr 28, 2008 | 02:49 PM
h22 civic's Avatar
i was talking to C.C yesterday at the track about the twin and they told me that you have to run the pedal stop because excesive clutch engagemnet on the pedal destroys the fingers..i dont run one either and had it for a few years with no probs. maybe its only the newer ones that need it
Old Apr 28, 2008 | 04:28 PM
22_42r_eg's Avatar
glad to know im not the only one w the problem. I have it packed ready to ship to comp. So far they have been very helpful w the whole situation.
Old Apr 28, 2008 | 07:23 PM
A train's Avatar
Default Re: (22_42r_eg)
you have to run the clutch stop oryou will damage the diaphram! period the other problem is you have to make sure when you put the tranny onto the motor the splines go easy into the two plates because they can get off a little when you start wobbling the trans to get the two to mate. CC the badest clutch around! chris came to see me from georgia last week here in cali, he always told me he would come visit and he pulled through!
Old Apr 28, 2008 | 07:32 PM
Default Re: (A train)
My diaphram is fine... Its the disk thats [freak]ed. Never had a problem putting the tranny in, and I do it ALOT!!!
Thanks though
Old Apr 30, 2008 | 08:16 PM
ive got my tranny hanging off... been prying on it HARD too, wont come off...Put the slave back on the treanny to try and see if i pushed the clutch in if it would pop off... MNo luck. It lets the tranny fall off a bit, but now I KN OW my disk is bent too.... Did you guys just pry the wholy [freak] out of it???
I have new disks on trhe way so i dont give a [freak] about these... But I dont want to [freak] something else up. IM SURE one of the disks is bent though just by how the tranny is trying to pull off, and it was most likely from prying it off since it was sure as hell assembled correctly.
Old Apr 30, 2008 | 09:15 PM
I'm surprised to see so many others with this issue. When mine went bad last year, I was told that this was a rare thing to happen. Another thing too is I havent seen any exedys with this issue, I've heard of a tilton but thats about it.
Old Apr 30, 2008 | 10:54 PM
Default Re: (reaction360)
GOt it off... Its [freak]ed. Need disks and ppilot bearing
Modified by extralargenog at 8:05 AM 5/1/2008
Transmission & Drivetrain
Mar 31, 2011 07:37 AM
Rrm101
Northeast (Sales)
Feb 3, 2009 10:26 AM
extralargenog
May 2, 2008 06:26 AM
