Allmotor total timing at WOT
Old Apr 27, 2008 | 02:38 AM
tianporn's Avatar
Default Allmotor total timing at WOT
Hey guys,
Just wondering what effect raising or lowering the ignition timing at WOT will do to your powercurve?
At the moment im running a street tuned AFR Crome map with stock P72 ignition timing so total timing at stock revlimit is 28deg.
I noticed the P30 stock basemap runs about 25deg total timing.
It would be good if everyone posts their total timing as well so we can compare.
My setup is pretty basic just stock JDM B18c (GSR) block and head with ITR cams.
Cheers
Old Apr 27, 2008 | 08:12 AM
mtber's Avatar
Default Re: Allmotor total timing at WOT (tianporn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
Cheers</TD></TR></TABLE>
Your timing values sound like they are in the correct ballpark.
Ignition timing values are going to be different depending on what engine management system you are using, what settings you are using etc.
Another major issue to consider is the fact that a lot of people don't properly sync their distributor timing to their engine management system.
Sync your timing, put the car on a dyno & start tuning
Old Apr 27, 2008 | 04:13 PM
93turbo16's Avatar
Default Re: Allmotor total timing at WOT (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Sync your timing, put the car on a dyno & start tuning </TD></TR></TABLE>
Exactly.
You have to understand that timing values are not really comparable between systems. And it is absolutely essential to sync your distributor before you start tuning or after you play with any intake cam settings.
Old Apr 28, 2008 | 04:32 PM
blackeg's Avatar
Default Re: Allmotor total timing at WOT (93turbo16)
i always hit my car with the timing light before dyno sessions
mortificationrock
Jul 10, 2007 04:26 PM
DOHCtah
Dec 3, 2004 09:47 PM
97vtec
Sep 23, 2003 10:25 PM
VSM EXtasy
Jul 19, 2003 10:19 AM
